pipe/hose?
fairly_odd
pipe/hose?
While getting our bongo worked on we've been advised on a deteriorated pipe or hose and can't find the name or a replacement part. its from the turbo to the intercooler, does anyone have any ideas what its called and where we can find a replacement?
- missfixit70
Re: pipe/hose?
Is it one of the large bore air pipes on here - http://www.lushprojects.com/bongopartsm ... mgno=.html
or here http://www.lushprojects.com/bongopartsm ... mgno=.html
- stilldesperate
- Tribal Elder
Re: pipe/hose?
Hi Martin,
There's a good database here http://www.lushprojects.com/bongopartsm ... 5tr.html#1
'fraid you might have to search a bit to find it, or i'm sure someone later will know which one you mean.
SD
SD
- stilldesperate
- Tribal Elder
- missfixit70
Re: pipe/hose?
In the right place at the right time & I knew where to look
If you look on the main site home page - http://www.igmaynard.co.uk/bongo/bongo.htm - several breakers/parts suppliers there, BongoBits, Bellhill, Ava, give them a shout & I'm sure they'll be able to help.
- stilldesperate
- Tribal Elder
Re: pipe/hose?
I'm usually in the wrong place at the wrong time ..... your honourmissfixit70 wrote:In the right place at the right time & I knew where to look![]()
SD
fairly_odd
Re: pipe/hose?
Thanks for the links, I think it is one of those large hoses. need to get 5 minutes peace from the kids to make sense of the diagrams though, i'm not mechanically minded
