Thanks bongoben, this is very helpful. I'm getting 57 across the resistor (shame - I was hoping there'd be no continuity, as it would be easy to solder on a new restor). The exposed part of the resistor is within a hairswidth of the gauge casing, but I don't think it is actually touching.bongoben wrote:On the bench it's simple enough.
Connect + 12 Volt to the IG terminal.
Connect - (ground) to the E terminal.
Connect about 5 - 10 ohms across the TU terminal and E terminals.
The gauge should swing accross to somewhere near maximum.
Experiment with it, different values will show different deflections.
The gauge is adequately protected and you will do no harm.
I you still get no movement then you will have to strip out the gauges.
Addendum.
As far as the resistor shown above is concerned, measure it with multimeter,
it should be 56 Ohms I think, maybe more, the case is high temp insulation
and a bit missing is not much of a problem, test it for continuity.
I'll see if I've got any resistors knocking around to put between TU and E. If not, then I guess a low voltage cell would do the trick instead?
