cheers jim
fuse
Bhongo Bhoy
fuse
HELP
i removed the top left small 10amp fuse in the fuse box and my cab lights went off but when i replaced it they came back on except for my dashboard lights
what have i done and how do i fix it
cheers jim
cheers jim
steviebongo
- Tribal Elder
Re: fuse
hail hail, don't think the cluster illumination is linked to the courtesy lights ?
Bhongo Bhoy
Re: fuse
do you stay anywere near were you got youre windows tinted ?
if so are you any good with electrics
i done this tonight when trying to fit the spotlights to my new bullbar as i thought i knew how to do it but maybe i should have waited till it was light
should have wrote Stevie at the top of this
again im blaming the stella
steviebongo
- Tribal Elder
Re: fuse
there might be another fuse away that deals with the exteroir lights ,in fact most defo there will be and yes i stay 10 mins from it .
Bhongo Bhoy
Re: fuse
the exterior lights are all working fine as i drove back from work earlier but the switches that are wired up for the fog light (no fog light connected) lit up before and doesnt now so im thinking it could be that one so ill connect the fog light in the morning and see if that works.
ps is it you i pass at bearsden asda regularly ? im in a green aft with the decals removed from the aft .
Re: fuse
Fuse 8 in the engine bay 15A will service the dash lights & yer tail...
In fact that explains why yer fuse went... (A short may have blown the fuse) & the chance is your tail lights don't work either...!Bhongo Bhoy wrote:the exterior lights are all working fine as i drove back from work earlier but the switches that are wired up for the fog light (no fog light connected) lit up before and doesnt now so im thinking it could be that one so ill connect the fog light in the morning and see if that works.
Bhongo Bhoy
Re: fuse
jaylee wrote:Fuse 8 in the engine bay 15A will service the dash lights & yer tail...
spot on Jaylee never even checked my tail lights last night
thanks to all
Jim
Re: fuse
He's getting a bit good at this diagnostics stuff is JayleeBhongo Bhoy wrote:jaylee wrote:Fuse 8 in the engine bay 15A will service the dash lights & yer tail...
spot on Jaylee never even checked my tail lights last nightall sorted now .
thanks to all![]()
Jim
