On checking fuse box this is where the fuse is removed & replaced with the blue wire from the Willinton kit, have checked the fuses on the kit & all seem intact. Any ideas please
Blown Fuse?
Blown Fuse?
Hello, I have a problem with radio - mirrors - cig lighter not working, this seems to indicate that number 8 fuse has blown.
I intend to live forever - so far, so good!
Re: Blown Fuse?
Sounds like your leisure battery has gone flat
Try putting the normal fuse back in to see if it works then.
Re: Blown Fuse?
Thanks John, LB is ok though, I caused the problem myself by pluging untested lead into cig lighter.
Re: Blown Fuse?
Seen this before when on the Italian trip earlier this year... A fellow Bongolier had the same problem.
It was a fuse from the LB to the radio - mirrors - cig lighter circuit under the bonnet near the back of the bay!
Re: Blown Fuse?
Thanks for that jaylee, will check it out in daylight tomorrow.
Re: Blown Fuse?
All sorted now, took her down to Allans in Plymouth & had a free winter check at same time, also fixed me up with full size spare wheel to replace the skinny.
The mans just magic with Bongos.
