Thanks Jon
Head Bolt Torques
monksie
Head Bolt Torques
Could someone please supply me with the torqe settings for a 2.5 diesel bongo. This is the WLT motor.
Thanks Jon
Thanks Jon
Re: Head Bolt Torques
As far as I can work out from the Service Manual there are 3 tightening stages:
1) Tighten to 29Nm (3.0 kgf.cm)
2) Tighten each bolt by a further 90-105 degrees
3) Tighten each bolt again by a further 90-105 degrees
However I haven't done the job, so you might be best to wait until someone who has comes along & confirms the procedure
And just in case, and not that I know much about it all but people often point it out, a reminder that the bolts are use once only stretch bolts - the old ones should not be used again. Apologies if you know that (I'm sure you do) but best said just in case.
PS - if in a hurry then have a search on here as I'm sure the figures have been given out before by people like Dandywarhol and Simon Jones (just two who come to mind) who have experience
monksie
Cheers for that. Its a great help
