My air con appears to be working as you can hear it under the bonnet but the fans are not blowing anything through.. the gauge says it's like 32 degrees but I can't demist the windscreen..
Any ideas?? I just need the fans to blow!!
Many thanks,
Dee
Hi,sounds like a link or operating rod has come off the flap mechanism.Kitegirl wrote:Hi all,
Many thanks,
Dee
Should do, but only as dehumidifier, not in order to get down below the already v. low ambient air temperature (why would anyone want to?rita wrote: I Dont think your air con will work in this weather.
Heaters heat, aircon coolsB*Witched Blingo wrote:Does aircon not warm as well as cool? Alright, stop flippin shoutinI really don't understand how it works. I know I can hear mine kick in and out as I flick from aircon/aircon econ and then to normal.
Indeed!B*Witched Blingo wrote:Does aircon not warm as well as cool? Alright, stop flippin shoutinI really don't understand how it works. I know I can hear mine kick in and out as I flick from aircon/aircon econ and then to normal.
Now that really DOES baffle meIn winter you should use the aircon system to warm your vehicle.
I'd have thought any half decent garage / auto-electrician shold be able to diagnose this (and possibly fix it but costs are hard to estimate). It sounds like either power isn't getting through (fuses?) or the resistor has blown (but you say no heater fans are working so I presume the rear one isnt either). I understood that usually when the front fan blows the resistor through running too sliffly, that it often still works on the 'full' (4) setting. Since the rear fan will not work anyway unless the front fan is set to 1 or greater, maybe the rear is being affected by the front fan situation. Before going to garage, I would:Kitegirl wrote:Thanks people![]()
My blowers are not blowing at all, not anywhere... there is the whirring under the bonnet that I believe is the air con working, but nothing coming from any blowers anywhere throughout the van.
What kind of place would I need to take it to to fix the problem?
Would any garage be able to sort it?
This stuff makes my brain hurt....
I have another issue that I'll post about separately, but it just seems to be one thing after another at the mo..
Much appreciated on the responses, I don't know what I'd do without this place!
Dee
