Long Warm Up Time
Re: Long Warm Up Time
Post by francophile1947 » Fri Dec 04, 2009 7:37 pm
mikeonb4c wrote:Wish I'd asked for the old faulty one on my Nissan Sunny to be returned to me for analysis as it was one that definitely failed leaving the passageway permanently open..
Years ago, thermostats always used to fail in the open position :D It seems a damned silly idea for them for fail in the closed position - a definite backward step that could cost a blown-up engine :roll: :roll:
smac02
Post by smac02 » Fri Dec 04, 2009 8:36 pm
Check your water level. No water no warm up. May sound sound silly but I have experienced this on a couple of cars where the water level has dropped.
wishmaster
Post by wishmaster » Fri Dec 04, 2009 9:59 pm
The LPG system uses heat from the engine coolant and from cold runs on petrol until the coolant is 40 degrees, hence the comment above.
Interesting is that Andy as our V6 LPG runs on petrol until the coolant reaches 50 degrees, tried it at 40 when we first had it converted but it started hunting for revs and then stalled :o , hence the tweak to 50 degrees, runs lovely now :D .
As for warm up, the heater is blowing hot air quiet quickly, but we have had a full flush and new antifreeze/coolant and bleed recently though.
Iz
I have a plan and its as HOT as my pants
IZZY
http://s633.photobucket.com/albums/uu57/izzy2619/
apole
Post by apole » Sat Dec 05, 2009 12:44 pm
Hi Izzy, some systems can run from cold, my smart with the same prins system cuts in at 27 degrees. Originally this was the setting for the bongo but it suffered as yours did so they moved up to 40, ok 99% of the time but very cold weather it might hunt although in the summer we changed the pipework so it has a much better coolant flow.
Andy
mobilecat
Post by mobilecat » Sat Dec 05, 2009 2:53 pm
Mine warms up fine but the heating has always takena good 10 minutes to kick in - no matter what time of year and coome what may. Been that way for the 2 years I have had it but works fine once it wakes up :)
Post by Ian » Wed Dec 16, 2009 9:45 pm
missfixit70 wrote:
Ian wrote:
apole wrote:Hi there,
Yesterday I went out in the bongo and found that it didn't properly warm up for nearly 10 miles. That is very much longer than it has ever taken, normally the gauge is up in a mile or 2. Heater wasn't that much cop either.
Thinking my thermostat is pooped, luckily a new one is going in next week.
I appreciate the colder weather will have an impact but never taken that long before.
Anyone else had this?
Andy
I'm experiencing exactly the same problem on my V6, plus an additional fault. The oil light flickers on and off until the engine is fully warm. Then it goes off, and stays off.
The diesel has a low level indication on the oil pressure light, wonder if the V6 does too? worth checking the level, especially if it's not long since been done, may be a slight leak on the filter or plug, or it could just be the level was a bit low from the oil change & it's only showing up with the higher viscosity in colder temperatures (slower return to sump on cold start up?)
It was the pressure switch, which needed replacing. BTW, the oil pressure switch for the V6 is the same as that found on the diesel engine. 45 minute job at the garage, £25 labour, I supplied the switch.
Post by mikeonb4c » Wed Dec 16, 2009 9:53 pm
Ian wrote: It was the pressure switch, which needed replacing. BTW, the oil pressure switch for the V6 is the same as that found on the diesel engine. 45 minute job at the garage, £25 labour, I supplied the switch.
Marvellous. One bit of the world of automotive problems that hasn't changed in 40yrs then, when my old Morris 1000 showed the same symptoms and responded to the same treatment :lol: :lol: :lol:
