Hi Peeps,
The light behind the gear selector has gone out. How easy is it to get to and change, and what bulb do I need to get?
Many thanks, Toni.
Auto Gear Selector Light
tonic
Re: Auto Gear Selector Light
One of the little capless sidelight bulbs.
Like this http://www.consumabulbs.com/files/bdet.php?id=89
Changing it is a bit of a fiddle, but fairly obvious and straightforward once you've got the console off.
tonic
Thanks.
Is it a 12v 5w that I need to get? As I want to get one before I start dismantling.
Thanks again.
Thanks again.
I assume they are all 12v 5w if they are that size/fitting.tonic wrote:Thanks.
Thanks again.
I used a blue LED one to replace mine when it went.
It is the same as the one under the ashtray which is very easy to get to - check that first.
tonic
Thanks Scanner, got it all sorted with no bits left over.
