side door
Dunkie
side door
Post by Dunkie » Fri Dec 11, 2009 12:17 pm
my side door was working perfectly until last night.........now as far as i can tell it is unlocking but it is jammed solidly in place....could the auto close be holding it shut????? if so how do i de-activate it ???? i love my bongo ....didn't want a two seater
Re: side door
Post by g8dhe » Fri Dec 11, 2009 12:37 pm
Welcome to the forum.
A well known problem ! There is a factsheet in the Members area, see Top centre if you haven't yet had a chance to join. All though its free this month - so make the most of it!
Also several threads like this one, but a search will find plenty of posts like this. The key thing with the Big Thump approach is knowing the RIGHT place !
Dunkie
Re: side door
Post by Dunkie » Fri Dec 11, 2009 1:07 pm
:) cheers for the info shall have a thump or two on Sunday work keeps getting in the way when things like this happen........heres hoping it will be an easy fix :? :?
Dunkie
Re: side door
Post by Dunkie » Sun Dec 13, 2009 12:42 pm
Dunkie wrote::) cheers for the info shall have a thump or two on Sunday work keeps getting in the way when things like this happen........heres hoping it will be an easy fix :? :?
well 2 hours getting covered in the black goo and no closer yet.......shall try a bigger hammer
You've Been Bongod
Re: side door
Post by You've Been Bongod » Sun Dec 13, 2009 12:48 pm
Dunkie
i have found the bigger the hammer the better :shock:
Dunkie
Re: side door
Post by Dunkie » Sun Dec 13, 2009 6:00 pm
well it's now working =D> (jammed cable mechanism..) ........ nearly chopped finger off :shock: shall have to remember if it happens again once more thanx for the advice
Re: side door
Post by mikeonb4c » Sun Dec 13, 2009 6:25 pm
Dunkie wrote:well it's now working =D> (jammed cable mechanism..) ........ nearly chopped finger off :shock: shall have to remember if it happens again once more thanx for the advice
Hurrah - another happy customer (with all his fingers intact....just :lol: ) :P
