Remote locking, fobs & blades...
Re: Remote locking, fobs & blades...
You can join 2 of the kit rods together as per the factsheet, and if you are a bit clever about where you put the joint you can adjust / tighten it through one of the existing holes in the door.
The amount of these I have gone through, great for taping cable onto and shoving through walls and ceilings or forming into hooks and picking up stuff that has fell down the back of the washing machine... oh they don't make em like they used to I agreejaylee wrote:I had the same problem & raided my mums closet & found (as i knew i would) some of those big gauge heavy duty old school wire coat hangers...!
I fashioned (no pun intended) the hanger into one long rod, connecting from the actuator with a secure link through the hole to the rod under the internal door lock button using the connector that came with the original (now redundant) short actuator rod. Making it easy to adjust the linkage without scraping the knuckles.. Works a treat!
The last time i used a hanger was when i locked my keys in the car in the 80's
They don't make coat hangers like that any more, & i even got a spare for helping with the guiding of the wiring through bulk heads!
Just don't tell my mum, she thinks i'm using em for a suit!!
The user formerly known as csmcqueen
スコット
スコット
I have to admit, i put my alarm locking controller gubbins inside the van.. The aerial (long distance transmitter sends a signal to the key fob & lets me know the alarm state.) is inside the windscreen pillar.. I felt that the constant use opening & slamming the door, plus possible water ingress may damage electrical components if situated in the door, & with the case of the one piece wire hanger...? Less connections to come loose, increasing longevity/reliability of the system..
(Not taking into account that i don't trust myself with my own workmanship)
- djswain1
- Bongonaut
djswain1 wrote:The kit arrived today with the correct key blanks hope to find time at the weekend for fitting & to get the keys cut
davelou wrote:Hi dave,
I bought a similar kit from rightclick but found that the mazda key blanks don't work they are too smallHow did you find them
Dave
Still working OK though
Dave & Jo
2.5 TD auto 4WD AFT 8 seater
T4 Fiamma bike rack
T4 Fiamma bike rack
At least you can order spare blades for their remotes, in fact you can order spare remotes toodjswain1 wrote:djswain1 wrote:The kit arrived today with the correct key blanks hope to find time at the weekend for fitting & to get the keys cutdavelou wrote:Hi dave,
Dave
I'm afraid I misinformed you! when I went to get mine cut they were too small... same basic pattern but shorter.. sorry about that. I think a standard key cut down will probably do the job though? I will investigate this further.. The key cutters may even be able to cut down the end of the key on their cutting machine??
You need to order the MA20 (grooved key blanks) these fit perfectly when cut as the lock ignores the groove, locksmith will probably say cant be done but convince him it works... because they do
Rightclick Key Blanks
To be safe i would order a spare too and take them to get cut, just in case they make a mistake like my cutter did, and i had to order another spare
スコット
スコット
TINCA TINCA
Can I just ask a question on this link.....Have searched a bit but thought I could creep in and get an answer from you knowledgeable guys and girls.
Central locking keeps going duff because of the wiring in the door. Hubby fixed a couple of times....is there a way to stop it happening. Wires are so tight.
Also our "Blipper" packed up quite a while ago and as people have said it is amazing how annoying it is without one. We have taken it to a "Specialist" who tried for an hour to find the problem....decided we needed a NEW ONE....Asked the price ......£180
Would rather go on holiday with that money and keep opening doors manually with key.
Just wondering if anybody out there has replaced the "BLIPPER" and what is involved and where to purchase one. Obviously I might get some replies about links etc. which I will follow up.
Answers can be technical as it is NOT ME WHO WILL BE REPLACING WHATEVER IS NEEDED
If I were to do anything TECHNICAL it would probably end up with the doors flying open on the motorway
Thanks for your time.
- hembramacho
I lost my fob recently, only for about 24 hours, but it was amazing how much a pain it was when you are used to remote central locking to go back to manually opening the door with the key!jimbo44 wrote:Can I just ask a question on this link.....Have searched a bit but thought I could creep in and get an answer from you knowledgeable guys and girls.
Also our "Blipper" packed up quite a while ago and as people have said it is amazing how annoying it is without one. We have taken it to a "Specialist" who tried for an hour to find the problem....decided we needed a NEW ONE....Asked the price ......£180![]()
Answers can be technical as it is NOT ME WHO WILL BE REPLACING WHATEVER IS NEEDED![]()
Andrew
- missfixit70
Cheaper to buy one of the kits talked about in this thread, bypass/remove the standard unit & fit a new control unit/receiver for £20 -£30 all in IMO if you don't want to go the alarm route.jimbo44 wrote:Can I just ask a question on this link.....Have searched a bit but thought I could creep in and get an answer from you knowledgeable guys and girls.
TINCA TINCA
Thank you will dig about now that we know it is possible.
BongoMTBer
Though I had better post my findings as I promised I would back in October!
I fitted the kit with folding key blades. All went well.
I had to join 2 rods together from a slave actuator to the lock in the drivers door and had a bit of an issue getting the key blades cut, but that was down to the key cutter making a mistake. New blanks are not expensive so it wasn't a big deal. A reccomended kit.
http://www.rclick.co.uk/product_info.ph ... cts_id=398
Mike_H
Hi Folks - I to am having issues to cause me to explore an aftermarket central locking system...my Bongo already has central locking with the fob on the head of the key (genuine Mazda), put hand in pocket on Sat to pull out a handful of "bits", the plastic body having disintegrated.
I'm pretty sure I wont get a genuine Mazda key for much short of a new mortgage, so...can I simply add a single door servo/motor & controller to the drivers door, and do I need a 2 wire or 5 wire motor ?
You shouldn't need to buy a servo for the drivers door as you already have central locking which means you already have one in the drivers door, your wiring will be a piece of cake to modify I would have thought.Mike_H wrote:Hi Folks - I to am having issues to cause me to explore an aftermarket central locking system...my Bongo already has central locking with the fob on the head of the key (genuine Mazda), put hand in pocket on Sat to pull out a handful of "bits", the plastic body having disintegrated.
スコット
スコット
Mike_H
Thanks Scott - I assume I can just use the "new" control unit to drive the servo....doh! makes perfect sense when you think about it.
