thermostat question
thermostat question
could the gasket to this be described as an o ring
asked a seller if gasket comes with it and he says its an o ring
- stilldesperate
- Tribal Elder
Re: thermostat question
It's (as far as I remember), a rubber seal, "U section", that fits round the outside of the 'stat.
Was on the one from the Bongo shop I bought last month.
SD
SD
- missfixit70
As SD said, this should help - http://www.igmaynard.co.uk/bongo/forum/ ... 3&start=75
- haydn callow
I think some would describe it as a 'O' ring...it fits around the rim/edge of the stat and seals the joint
- widdowson2008
This is the cross section of the stat flange gasket
wonkanoby - find another seller cos the one who said its an 'O' ring is lying. (he has probably never seen one)
Steve
- haydn callow
Thats a bit strongwonkanoby wrote:could the gasket to this be described as an o ring
Seems a fairly reasonable non techie answer to me
- widdowson2008
Ok - I'll rephrasehaydn callow wrote:Thats a bit strongwonkanoby wrote:could the gasket to this be described as an o ring
asked a seller if gasket comes with it and he says its an o ring![]()
- could the gasket to this be described as an o ring? No
- asked a seller if gasket comes with it and he says its an o ring By the seller, I assumed wonkanoby meant the guy who was selling the thermostat. If it is, then the seller has obviously picked up the wrong stat if the one he is trying to sell comes equipped with an 'O' ring.
There is absolutely no reason I can think of why 'O' rings will not work, but why change a design feature?
So whilst .... the one who said its an 'O' ring is lying is probably a tad strong, I think find another seller is not too far off the mark. If he got the seal bit wrong, he may also have got the stat bit wrong as well.
With the Bongos known cooling system fickleness, would you introduce an unknown into the equation? I certainly wouldn't.
Steve
- widdowson2008
Nothing like an 'O' ring Haydn - totally different animal. Sorry - I get a bit pedantic about terminologyhaydn callow wrote:I think some would describe it as a 'O' ring...it fits around the rim/edge of the stat and seals the joint
Steve
As an aside, why are 'O' rings called 'O' rings? Why not just rings, or 'O's? I can't think of any type of ring other than an 'O' shaped one. Not as if you get a 'W' ring, is it?
- stilldesperate
- Tribal Elder
The "O" is the section of the rubber, the "Ring" means it's not square.....
SD
SD
Sounds fair enough - so is the thing round the outside of the stat actually a 'U' ring? or perhaps a 'C' ring?
- stilldesperate
- Tribal Elder
In mathematics, the category of rings, denoted by Ring, is the category whose objects are rings (with identity) and whose morphisms are ring homomorphisms (preserving the identity). Like many categories in mathematics, the category of rings is large, meaning that the class of all rings is proper. (Wikipediadave_aber wrote:Sounds fair enough - so is the thing round the outside of the stat actually a 'U' ring? or perhaps a 'C' ring?
Simplezz.....
SD
- stilldesperate
- Tribal Elder
Quick google reveals (I think!) that a U ring would have the open side either up or down, whereas a "C" ring has the open bit on the inside.
So I guess it is a C clip.
- widdowson2008
Don't want to confuse, but the 'U' ring seal is also known as a 'V' ring. They are commonly used on hydraulic rams/cylinders to withstand huge hydraulic pressures.stilldesperate wrote:Quick google reveals (I think!) that a U ring would have the open side either up or down, whereas a "C" ring has the open bit on the inside.
Steve
Bhongo Bhoy
widdowson2008 wrote:Don't want to confuse, but the 'U' ring seal is also known as a 'V' ring. They are commonly used on hydraulic rams/cylinders to withstand huge hydraulic pressures.stilldesperate wrote:Quick google reveals (I think!) that a U ring would have the open side either up or down, whereas a "C" ring has the open bit on the inside.
so would 2 V rings make a W ring
