Previous to this, It had a new rad fitted, Thermostat removed and some sort of head sealer used, This cured the problem for a couple of months, The amount of time i have owned the bongo, Say no more,
To cut a long story short,
The new head i have got has only two pipes coming from the press in fitting at the front that i can deal with, I will add a t piece so i have the bleeding pipe, (Excuse my French),
It also came with some press in fittings and brass washers to go in the injector holes,
It is a patent copy head, Hmm,
My Questions are, Has anyone here fitted one of these heads, And is it possible to fit these parts myself, How do i get the pipe in and be sure of a good seal, and do the injector fittings just press in easily, I am hoping to get some info from someone that has succesfully carried out this job, Also What is the tappet clearance,
Thanks in advance, Any help will be appreciated,
Steve.
