Boxing Day morning. Everybody else in the house still sleeping it off. Good time to try to get our heads round this a bit more - I hope you're up and about, also fretting about it, Mike and Mike
Heres' some relevant, hopefully interesting, web pages - which I've also given numbers to, for simplified reference below.
1.)
http://en.wikipedia.org/wiki/Antifreeze
2.)
http://wiki.seloc.org/a/Organic_Acid_Technology
3.)
http://www.aa1car.com/library/2004/us120426.htm
4.)
http://www.sardracing.co.uk/xstream-gre ... -357-p.asp
5.)
http://www.sardracing.co.uk/xstream-red ... -359-p.asp
Overall (1,2 and 3), it's a confused picture, as much for the trade with stocking and specifying difficulty, as for us: E.G.,
"The question is, which type of coolant should you recommend to top off or refill a vehicle? The safe answer is the type specified by the vehicle manufacturer. But practically speaking, shops do not have the shelf space to stock different coolants for each different make of vehicle" (3.)
From that, I infer that you
can't necessarily trust what you are told by
"a decent motor factor or Motor shop..", as they're most likely to just try to find the nearest fit from what they stock, as opposed to the best choice for the application. Six months ago, I would also have said that they had a vested interest in selling OAT, for higher turnover and margin than from cheaper ethylene glycol. However, red Comma Xstream and green Comma Xstream are now being sold at the same price (4 and 5) - although, whether red Xstream really qualifies as a full-blown OAT coolant, I'm not sure. It's described (5) as
"Pure concentrate ethylene glycol, silicate free with Organic Acid Technology". From what it says in 1 though, it's probably the five years extended life which confirms that it is.
OAT
is clearly (1 and 2) mainly about extended corrosion inhibition life, and works by the inhibition chemistry being slower acting, therefore longer lasting. That in turn gives fewer toxic chemicals to be disposed of over time, hence the green push on car manufacturers to specify OAT - i.e., it is
not due to any intrinsic engine incompatibilty with proven ethylene glycol coolants.
Using 3 year green or 5 year red for only two years is therefore self-defeating, and might even mean that, with the slower acting corrosion inhibitors in red, you won't even get the same degree of protection. I will certainly run my green Xtralife (3 years life), for at least two and a half years, even after recently marginally diluting it with MotorMax. Then I probably will change to 5 years red, still with MotorMax if there are no problems meanwhile, now that green/red after-market prices have apparently harmonised - but I
will run it for its specified life, less an adjustment for MotorMax.
I don't think I'll be tempted by the after-market "universal coolants" also being offered (3), as I reckon they're more for the convenience of the trade, with their stocking problems, than for us.
BTW, the only significant problem with mixing red/orange, with green/blue, seems to be how do you then know what the remaining service life of the mix will be? Methanol (very toxic) is used as anti-freeze only in non-coolant applications, such as screen wash, de-icer, etc. (1), Mike.
