Need a Clock?
Barnet Al
Need a Clock?
If the absence of a clock from your Bongo is causing distress this may be the answer. Search e-Bay for item ref. 4651299252.
It is a clock in an ISO sized cubby box that is the right size to fit the hole above a standard sized radio.
The guy is only selling one (£12.99 + P&P) but seems to have them on offer every 10 days or so and they come with the plug and abouit 9 inches of wire which mekes instalation a doddle.
I had one from him about a month ago and it fits fine. As its from a BMW you will have to use your skill and judjment and a Stanley knife to modify the 4 retaining lugs on the back but it is possible to get a good fit.
The 3 wires may well be long enough (mine were) to connect directly into the radio loom, you will need to sort ouit which goes where as I didn't take notes at the time. I believe the backlight is red but can't be sure as I haven't driven in the dark since fitting it.
I believe Mazda also use this on some models but tha last one I saw on e-Bay went for over £50 and I don't know if it had the plug and wires.
Hope this is usefull to someone.
- dandywarhol
Good tip and welcome Barnet...........I just got a similar one from a 3 series on evilbay last week and fitted it at the weekend.
They look just fine and dandy.......although finding a suitable wire for the light was a pain in the proverbial
pippin
Dave up north
A better one is the MX5 Din Clock.
Fits better, wires easier and its prettier.
But I suppose ANYTHING is better than the crap halfords one I have stuck to me dash. Cant see it at night unless you scrabble about for the backlight button.
Note to others - Too late for me - Alpine stereo's dont always have a clock display option. If you bin the Mazda stereo, Make sure your new stereo can display time.
- dandywarhol
Doesn't work Bruce, tried it, but the parallax is ok.....it's only a timepiecepippin wrote:Trouble is, for the driver the clock really needs to be on the right hand side of the unit and thus closer.
I assume that because the dial face is totally symmetrical the whole unit could be fitted upside down so that the clock is closer to the driver?
- dandywarhol
Barnet Al
You did well then Dandy, did that include the cubybox? I notice some are selling the clock on its own.
I raised this initially as the fixed price seemed reasonable and the plug and wires are a definite bonus. The mazda one may fit without altering the fixing lugs (perhaps others can confirm) but I doubt you will get one anywhere near the price without slogging round the breaker's and haggling with the management.
Yes Nick 65 you are right, East Barnet actually so I know your old stamping ground well.
- dandywarhol
Yep, got the lot for that money, just clips in to the hole in the dashBarnet Al wrote:You did well then Dandy, did that include the cubybox? I notice some are selling the clock on its own.
