The only other reference I can find in the manual is, under "installation of timing belt", a one-liner:mikexgough wrote:surely there must be at least a Static timing set up too in the manual....... then it can be done with the strobe etc after.....if not where do you start?
"6. Start the engine and check the following. (1).......(2).....the ignition timing. (3)...."
There's no detailed explanation there of how to check it, statically or otherwise.
Ignition timing (checking and) adjustment, as in my earlier post, is only fully described under an integrated "Engine Adjustment" section, where it is only done dynamically, with pre-warmed engine and other specified conditions, and within a specified idling range.
