My wife and myself have had enough of the problems now (what with getting side swiped by a hit and run white van and still waiting for the panel to come from Japan and now this) could it be that the cooling system is patly frozen? i think once we get things sorted we will be leaving the bongo clan and sell our beloved beast, anyone know what an m reg diesel fetches at the mo?
Overheat again
nigelginny
Overheat again
Hi, had another overheat in the beast again, the low level alarm didnt sound when we first switched her on, im wondering if the mix of antifreeze was correct maybe the header tank was frozen
we only trvelled about 3 miles and the temp went up into the red, well this morning i topped her up with 5 ltrs of neat antifreeze and bled the system, i took nher for a drive but only went about a mile when the same happened but not right up to the red, up about three quarters of the way, i suspect the head has gone again.
- mikexgough
Re: Overheat again
Sounds like the coolant mix was poor to me and it has been very cold over the past few days across all of the UK...... my mix is 50% ratio ( which is approx protection to -37) and I use my Bongo daily.....if your mix is low and you don't use often then the the coolant can freeze quite easily
Re: Overheat again
V.sorry to hear your bad newsnigelginny wrote:Hi, had another overheat in the beast again, the low level alarm didnt sound when we first switched her on, im wondering if the mix of antifreeze was correct maybe the header tank was frozenwe only trvelled about 3 miles and the temp went up into the red, well this morning i topped her up with 5 ltrs of neat antifreeze and bled the system, i took nher for a drive but only went about a mile when the same happened but not right up to the red, up about three quarters of the way, i suspect the head has gone again.
My wife and myself have had enough of the problems now (what with getting side swiped by a hit and run white van and still waiting for the panel to come from Japan and now this) could it be that the cooling system is patly frozen? i think once we get things sorted we will be leaving the bongo clan and sell our beloved beast, anyone know what a n m reg diesel fetches at the mo?
Not a lot I can say except good luck getting it sorted. As for what's wrong, maybe wait and see what the garage assessment is before assuming the worst.
nigelginny
Re: Overheat again
Thanks, i just cant see it being anything else, no leaks, we also had a strange bubbling noise coming from the engine when it first happened, another strange thing is , when i bled ithe system i couldnt get heat from the heaters?
Re: Overheat again
Sounds like coolant isn't circulating - maybe frozen, or pump/belt gone.nigelginny wrote: another strange thing is , when i bled ithe system i couldnt get heat from the heaters?
In your position, if you can get it bled properly and are still having problems, I think I'd give serious consideration to spending £30 and using Steel Seal.
nigelginny
Re: Overheat again
steel seal, whats that?
Re: Overheat again
Several threads on it if you search for "steel AND seal" - here's one of them http://www.igmaynard.co.uk/bongo/forum/ ... al#p366067nigelginny wrote:steel seal, whats that?
nigelginny
Re: Overheat again
Thankyou, i had a bit of a think last night and the more i think about it the more i convince myself that maybe the fanbelt could be the trouble, anyway i'll check it out later today and let you know, if not then the steel seal looks like the next step. i havent had any white smoke and the van starts with no probs.
- haydn callow
Re: Overheat again
I wouldn't put that steel seal in untill you are sure you have a cylinder head problem
Re: Overheat again
Agreedhaydn callow wrote:I wouldn't put that steel seal in untill you are sure you have a cylinder head problem
nigelginny
Re: Overheat again
all three belts are ok, its fine all the time its idling but as soon as you take the revs up the temp gauge rises.
Re: Overheat again
Is the coolant actually circulating? - you should be able to tell with the filler cap removed. If not, and your hoses are soft (not frozen), it sounds like the water pump may be faulty - several members have had that problem.
nigelginny
Re: Overheat again
The coolant seems to be moving i.e rising and falling, i bled the system for a while but still have the same prob, still cant get heaters to warm up?
Re: Overheat again
Coolant will rise and fall because of the air in it.
You should be able to actually see if it is being pumped around if you remove the filler cap (with, of course, the engine cold - don't want you getting covered in boiling water
). As you can't get either heater to work, it really sounds like the water isn't circulating and the heaters are full of air. When you rev the engine hard, does any coolant come out of the filler cap?
Re: Overheat again
Stay calm, eliminate the possibilities as per posts above, don't drive it into the hot zone until other stuff has been checked/actioned. Good luck
PS- does header tank level vary depending on engine revs. I've no idea if it would/should in the event of a faulty gasket but I'd be curious to know.
