oohps my radio has stopeed working
My radio was working fine this morning but on the afternoon school run it wouldn't come on. It is connected to the main battery and has never had an issue before. Could it be a fuse? If it is a fuse, where do I find it and which one will it be. Thanks everyone.
- You've Been Bongod
Re: oohps my radio has stopeed working
cath if wired straight to the battery it should have a inline fuse along the wire from live to stereo failing that most stereo's have a fuse at the back of it
what make is it ????
Stupid question - will I need to remove it to check that or is it accesible round the back/side etc. I can't remember what make it is - Mike put it in for me when I bought it- I will look in the morningYou've Been Bongod wrote:cath if wired straight to the battery it should have a inline fuse along the wire from live to stereo failing that most stereo's have a fuse at the back of it
you will have to pull the stereo out to check the back of the stereo
best bet would be to contact mike if he fitted it for you
Hey I'm a girl but I am not that badYou've Been Bongod wrote:you will have to pull the stereo out to check the back of the stereo
- missfixit70
Fuse list in the facsheets in the members area - http://www.igmaynard.co.uk/bongo/member ... usebox.pdf - fuse 8 for stereo, mirrors & ciggy lighter.
Thanks Kirsty - although I think its one of the things I never got round to renewingmissfixit70 wrote:Fuse list in the facsheets in the members area - http://www.igmaynard.co.uk/bongo/member ... usebox.pdf - fuse 8 for stereo, mirrors & ciggy lighter.
Could be a fuse. Alternatively it's simply "stopped working".
It can happen!
I've had a lifelong love affair with radios and sooner or later most of them stop working, usually for reasons inside the box.
If it lights up etc. but makes no sound it's not the fuse.
Frank
It can happen!
Frank
They flew, I took up naturism
If you have a removable panel on the front of the radio, check that's not come adrift..?
- widdowson2008
Mine stopped yesterday. Got the radio manual out this morning to check where the fuse was. Manual shows it to be located on the back of the radio faceplate, so I took this off and .....................no fuse as per manual. Instead of the fuse, on the carcass fixed bit in the cubby, there was a 'reset' button - one of those things you press with something pointed (pencil).
So I pressed this and
it came on.
Took all of 20 seconds
Steve
No lights, no actionDiplomat wrote:Could be a fuse. Alternatively it's simply "stopped working".
It can happen!
Frank
First thing I tried - how hopeful was I?jaylee wrote:If you have a removable panel on the front of the radio, check that's not come adrift..?
Ooh there's some excitement to try in the morning.widdowson2008 wrote:Mine stopped yesterday. Got the radio manual out this morning to check where the fuse was. Manual shows it to be located on the back of the radio faceplate, so I took this off and .....................no fuse as per manual. Instead of the fuse, on the carcass fixed bit in the cubby, there was a 'reset' button - one of those things you press with something pointed (pencil).
So I pressed this andit came on.
- widdowson2008
