Hi this has probably been covered many time but What do S and L on the gearbox Do?
discolandjim
- dandywarhol
Re: S and L on the gearbox
Have a scan through the "search" facility at the top of the page Jim
To quote from the handbook S= for driving down hills use this gear as when an engine break is nessessary. the gears will change automatically between 1st and 3rd in response to the vehicle speed speed
L= use this gear when an extremely strong engine brake is nessessary the gears will change automatically between 1st and 2nd in response to the vehicle speed.
Colin
Colin
prior owner of >>>>1999 2.5 diesel ex tin top &FORD FREDA 2000 2.0 LTR PETROL
I found that the HOLD button does a similar job down hill - though I think it stays in 3rd - if not, I'm sure others will correct me. I often use it to slow me down coming up to junctions.
I'm finding my self driving the Bongo a bit like a manual motor these days when braking. As I approahc a slowing down situation, I first use HOLD whilst in D then, if need be, move lever to S (you don't have to press in the unlock button to do that, but it does prevent you moving into L by accident). In the snow recently, I would start in L (reduces chances of wheels spinning like mad). As I approached a junction at low speed, in L, I would use the HOLD button as a means of almost bringing me to a halt before I used the brakes. Worked well for me as a technique.
- Alacrity
- Tribal Elder
Spot on. S & L is manual 1st (L) & 2nd (S) - using the hold button gives (very good) engine braking in these gears, perfect for snowy/icy conditions when you need to avoid the (largely useless) brakes. In D with the hold activated you will pull away in 2nd & upshift to 3rd only. Again perfect for snow/ice.I'm finding my self driving the Bongo a bit like a manual motor these days when braking. As I approahc a slowing down situation, I first use HOLD whilst in D then, if need be, move lever to S (you don't have to press in the unlock button to do that, but it does prevent you moving into L by accident). In the snow recently, I would start in L (reduces chances of wheels spinning like mad). As I approached a junction at low speed, in L, I would use the HOLD button as a means of almost bringing me to a halt before I used the brakes. Worked well for me as a technique
I suggest taking it out somewhere quiet & playing with it based on what has been said above, that way you will get the feel of it. Don't worry about breaking something - the electronics will stop you doing something stupid. Selecting S or L with the hold button in can be quite a severe downshift if you are near the top end (rev wise) of the ratio being selected.
