Yep. Who needs it to beep when you got the mirrors closing too... Making a sound like an army of tree surgeons...csmcqueen wrote:solid ??? The earth shakesjaylee wrote:Great news! Locks with quite a solid clunk don't it.?
REMOTE LOCKING
Re: REMOTE LOCKING
Gaza69
Re: REMOTE LOCKING
Hey guys,
Have been reading this post with interest and also looked up the rightclick site. I found this kit:
http://www.rclick.co.uk/product_info.ph ... cts_id=768
Would this enable me to possibly link up my alarm system?
Im noy sure if i am capable of fitting these systems as im useless when it come to electrics. But il have a go atleast.
- missfixit70
Re: REMOTE LOCKING
You'll need an actuator for the drivers door with that kit.
Gaza69
Re: REMOTE LOCKING
Ty for lettign me know but what is an actuator, you mean a rod??missfixit70 wrote:You'll need an actuator for the drivers door with that kit.
Not off to a good start here am i....lol
Re: REMOTE LOCKING
Gaza69 wrote:Ty for lettign me know but what is an actuator, you mean a rod??missfixit70 wrote:You'll need an actuator for the drivers door with that kit.![]()
One o these.. Or something similar...?
- missfixit70
Re: REMOTE LOCKING
You'll need a rod & clamps with the actuator, it's the solenoid that physically operates the lock up & down when voltage is applied across it in either direction depending on whether you're locking or unlocking it. The drivers door doesn't have one as standard which is why it won't lock if you lock the bongo from the passenger side.Gaza69 wrote:Ty for lettign me know but what is an actuator, you mean a rod??missfixit70 wrote:You'll need an actuator for the drivers door with that kit.![]()
As Jaylee just beat me to posting a picture I won't bother
Re: REMOTE LOCKING
But your better with the wordiness...missfixit70 wrote:You'll need a rod & clamps with the actuator, it's the solenoid that physically operates the lock up & down when voltage is applied across it in either direction depending on whether you're locking or unlocking it. The drivers door doesn't have one as standard which is why it won't lock if you lock the bongo from the passenger side.Gaza69 wrote:Ty for lettign me know but what is an actuator, you mean a rod??missfixit70 wrote:You'll need an actuator for the drivers door with that kit.![]()
- missfixit70
Re: REMOTE LOCKING
Not sure if that's a compliment or an insult
Re: REMOTE LOCKING
Pick a window..missfixit70 wrote:Not sure if that's a compliment or an insult![]()
Always a compliment!
Gaza69
Re: REMOTE LOCKING
Thanks guys. i'l take a look, any of you had or seen a kit with everything all in for our bongos?
- missfixit70
Re: REMOTE LOCKING
Or try Maplins or ebay, just look for a kit with actuators or buy an actuator seperately. You can sell or pass the spare one on to someone else if you buy a 2 actuator kit.csmcqueen wrote:I have just this minute got in from fitting mine![]()
I bought the kit from Rightclick and got the 2 wire actuator from there to
I have mounted my control unit in the door itself, connected it to a permanent negative that supplies the electric window switch (Solid Black) and the permanent live from the original central locking switch (Blue/Black) these are the only two wires you need if you're not interested in wiring up the indicator/headlights etc, although I did mount a flashing led in the door so it shows me its locked![]()
Im not sure where you got it from Colin but they are easy to wire up, its fitting the actuator thats a pita, I did make my life easier by buying a length of Mild Steel as recommended by another forum member and it's better than joining a couple of the short bars together.
Scott
Re: REMOTE LOCKING
Fit the two & have the best of both worlds...!missfixit70 wrote:Or try Maplins or ebay, just look for a kit with actuators or buy an actuator seperately. You can sell or pass the spare one on to someone else if you buy a 2 actuator kit.csmcqueen wrote:I have just this minute got in from fitting mine![]()
Scott
Re: REMOTE LOCKING
I put two in the same door, gave em both names like Hacksaw & Terminoid, put em in little Lycra suites, cross wired em & took bets on the outcome...
Gaza69
Re: REMOTE LOCKING
You say fit the 2, haha, i dont know the first thing about fitting one!jaylee wrote:Fit the two & have the best of both worlds...!missfixit70 wrote:Or try Maplins or ebay, just look for a kit with actuators or buy an actuator seperately. You can sell or pass the spare one on to someone else if you buy a 2 actuator kit.csmcqueen wrote:I have just this minute got in from fitting mine![]()
Scott
Re: REMOTE LOCKING
I was kidding about the two>> (Check my post before yer last Gaza69.)
You only need one.. Two wires preferably..
