Brake fluid I intend on replacing with DOT5.1 would this be ok? What order would be recommended for the sequence? on a 1995 non ABS system using a traditional technique.
Thanks Bongo Forum rookie
Not something else to worry about will i never sleep. What do i look for and would it be covered by a service?missfixit70 wrote:He was looking at using Dot 5.1, don't know if that makes it compatible? that's if it's Dot 4 in there in the first place.
DOT5.1 is also glycol based - it's only DOT5 that's silicone based.wonkanoby wrote:how would you be sure you got all the old out
From above reply - Just pump until clean fluid comes out of the bleed pipe (not forgetting to check the level in the master cylinder regularly)
from that article
DOT 5 is silicone fluid and the above does not apply. Ideally, silicone fluid should be used only to fill non-ABS systems that have not been previously filled with glycol based fluid
so i would stick with dot4
..but then we're back to Square Onefrancophile1947 wrote:DOT5.1 is also glycol based - it's only DOT5 that's silicone based.wonkanoby wrote:how would you be sure you got all the old out
from that article
Any system that has used glycol based fluid will contain moisture, glycol fluid disperses the moisture throughout the system and contains corrosion inhibitors. Silicone fluid does not allow moisture to enter the system, but does not disperse any that is already there either
ditto. Bought the fluid and self-bleed kit when I bought the Bongo, all determined to do it. Then read of issues getting self bleed kit to work on reservoir cap without putting a hole in it. Didn't like that. Never got a round tuit. Did a reality check. Did my Nissan Sunny have a brake fluid change in its 18 year life? Did it eck as like. Seems to me that if everything feels OK, it is OK. My guess (but correct me if wrong) is that excess moisture should display either as spongy brakes (water boiling in region of cylinder) or as a moving part seizing up through corrosion. Neither is likely to happen suddenly and catastrophically so I can afford to take a personal view without endangering life and limb.missfixit70 wrote:I doubt fluid replacement would be covered by a standard service, even though it's recommended it's done every 2 years, I know I haven't done mine in nearly 3 years of ownership, but it's on the roundtuit asap list. Not a huge job, basically just got to pump new fluid through the system & make sure it's bled through with no air bubbles.
