Cant find the problem....pls help !!!
- widdowson2008
Re: Cant find the problem....pls help !!!
Could it be one of these pulleys you are looking at?
Steve
- widdowson2008
This any good?FREDA MIND wrote:hi guys, interesting thread,,, ive got to change the water pump in next few days, how tight do the aux drive belts need to be???
cheers ricky
Steve
- dandywarhol
Sounds like the crank pulley is brokenthe guvnor wrote:I have investigated more in daylight lol...........hope you slept widdowson
ok so i was sort of correct in what i rememberedthe 'loose' pulley i refer to sits directly behind the crank pully ! this is were the drive belts sit, it is seperate to were the belt for the air con sits and it does not obviosly move wen the belts are on because of the pressure but with no belts it seems to slide freely from side to side. after looking more closely and adjusting/ loosening a few belts i may have cured the main noise
will now more when i start her from cold (sounded like a bag of bolts this morning !!!!) but i still have a sound that i hope resembles tappits. Looks like it could be the next job on the list !
Still not sure if the said pully is meant to be like it is though !!!!!!!
Is it item 11-371? http://www.lushprojects.com/bongopartsm ... mgno=.html
FREDA MIND
thanks widdowson thats just what i was looking for , thankyou v muchwiddowson2008 wrote:This any good?FREDA MIND wrote:hi guys, interesting thread,,, ive got to change the water pump in next few days, how tight do the aux drive belts need to be???
cheers ricky
hope you solve your problems.
ricky
have yourself a midlife chrisis,,,,go buy a bongo!
I would agree with Dandy,could be the Harmonic Damper has parted company.dandywarhol wrote:Sounds like the crank pulley is brokenthe guvnor wrote:I have investigated more in daylight lol...........hope you slept widdowson
Still not sure if the said pully is meant to be like it is though !!!!!!!![]()
the guvnor
11-371 is the pulley, looking at the pic...........it does look broken
- widdowson2008
Looks like dandywarhol is right - Crankshaft pulley item 11-371
If you do have to replace this, I would suggest you get the key as well 11-301J.
If the pulley has broken and been wobbling loose on the shaft, the key will very likely be damaged.
Steve
the guvnor
I am booked in at AL motors on monday. Have spoke to the guys and they have said they will look at it but chances are it is the damper betweeen the two pulleys !! They will look at at to confirm.
Thanks for all your help guys, a strange outcome, but another thread that may help another bongo !
Well done everyone and thankyou again
