Is this a speedo chip or part of the loom???
Re: Is this a speedo chip or part of the loom???
well it says GA5R on the dial so that'll do nicely
Regards Ray & Christine
falcoron
anyone know which would fit my 2.5 diesel 1995?
falcoron wrote:anyone know which would fit my 2.5 diesel 1995?
the same one mate keep an eye out on ebay or local scrappy.
- mister munkey
MX6 is a GA5R too.
I'm starting to collect them from my other forum.
Might have a couple spare soon . . . .
falcoron
Triple/R wrote:falcoron wrote:anyone know which would fit my 2.5 diesel 1995?
does it just pop straight in. I can do that ok just had mine out to fit a mason. but mine reads mph but trip is kms
is clocks exactly the same configuration? have seen some on ebay with temp gauge on oposite side of facia
I got a 626 instrument unit, removed the GA5R speedo from it, and it just dropped in to the Bongo instrument cluster. Reads Miles / MPH very accurately compared to my GPS. You can't fit the whole 626 binnacle in though.
- BONGODADDY
I have just purchased one of those speedos (Just waiting for it to arrive) pretty much the same situ as you, i have a chip as well, maybe i could bring it along to Tackeroo2 and you could shout instructions at me as to how best to tackle the job
Or i could make the tea
See you soon mate
Paul.
- maxheadroom
No probs Paul i'm sure we can sort it~did you get the clear plastic front that covers the dials cus sometimes the trip button (on your new one) is thicker & wont go through the hole so you have to make hole bigger with a slightly bigger drill bit or summat similar.BONGODADDY wrote:Hi Ray,
I have just purchased one of those speedos (Just waiting for it to arrive) pretty much the same situ as you, i have a chip as well, maybe i could bring it along to Tackeroo2 and you could shout instructions at me as to how best to tackle the job![]()
Or i could make the tea![]()
See you soon mate
Paul.
- maxheadroom
or just swap the Bongo trip button over it's only one screw if I remember rightTriple/R wrote: No probs Paul i'm sure we can sort it~did you get the clear plastic front that covers the dials cus sometimes the trip button (on your new one) is thicker & wont go through the hole so you have to make hole bigger with a slightly bigger drill bit or summat similar.
Nice one did'nt know thatmaxheadroom wrote:or just swap the Bongo trip button over it's only one screw if I remember rightTriple/R wrote: No probs Paul i'm sure we can sort it~did you get the clear plastic front that covers the dials cus sometimes the trip button (on your new one) is thicker & wont go through the hole so you have to make hole bigger with a slightly bigger drill bit or summat similar.
It's thanks to you Max for spotting this in the first place that people like me (useless with electrics) can do job's like these~but will probably take me more than ten minutes~but whats the rush as long as result is same
- BONGODADDY
Sounds like you both know what you are doing so i will bring the whole thing to Tackeroo as it is the complete cluster and when i get back from fetching the wood it will all be done !!
Paul.
