Tyres 215 all round or 215 and 195?
dobby
Post by dobby » Sun Feb 28, 2010 5:46 pm
Ok
Need some definitive advice :lol:
Bongo needs four new tyres, it's over at Ian Taylors Bongo Health Farm having a holiday (service, MOT, derustification)
Should I go for 215 width front and rear or do 195 front and 215 rear as per standard?
Tyres will be fitted to standard SP pack alloy wheels (are they all the same width)?
Lastly, what's the benefit of 215's all round - does it make the steering heavier?
BONGODADDY
Re: Tyres 215 all round or 215 and 195?
Post by BONGODADDY » Sun Feb 28, 2010 6:32 pm
Hi Graham,
I am no expert but i can let you know that i have 215/65/15's all round on alloys, they are 100 rated and the ride and handling seems very good, don't really notice bumps in the road and the tyres grip very well in the wet as well.
Hope this helps mate.
Paul.
[/b]
Post by Bob » Sun Feb 28, 2010 6:35 pm
There's a Fact Sheet on tyres in the Member's area, well worth a look.
Essentially you can fit the same all round, or original sizes. It's critical on a 4wd to have the same circumference though and either route will achieve this. :)
You've Been Bongod
Post by You've Been Bongod » Sun Feb 28, 2010 6:52 pm
graham isnt yours a 4wd???
if it is i would stay with the same size all round 215's
if its 2wd then 195 front 215 rear
dobby
Post by dobby » Sun Feb 28, 2010 7:31 pm
You've Been Bongod wrote:graham isnt yours a 4wd???
Thanks all, the fact sheet is pretty clear about it.
Carl - it's a 4wd and they are 195F and 215R as well
Going to get 215's all round via Mr T
splitpin
Post by splitpin » Sun Feb 28, 2010 8:16 pm
Mine is 4wd and I've had both combinations fitted, didn't notice any difference in feel or handling either way but steering was a bit heavier with the 215/65 size on front. Recomended sizes according to handbook are 195/70 front 215/65 rear wether 2wd or 4wd.
David Edwards
Post by David Edwards » Sun Feb 28, 2010 10:12 pm
I have been running on 215's all round since I bought it, no probs, just remember the speedo will probably do what mine does,lol, record 5mph faster than you are actually doing, I am not bothered about it as it helps with speed limits,lol.
Post by missfixit70 » Sun Feb 28, 2010 10:16 pm
215 is the tyre width David, so it depends on the diameter as to the speedo reading. I found my 215/55/17's put the speedo & trip counter spot on 8)
dobby
Post by dobby » Sun Feb 28, 2010 10:17 pm
splitpin wrote:Mine is 4wd and I've had both combinations fitted, didn't notice any difference in feel or handling either way but steering was a bit heavier with the 215/65 size on front. Recomended sizes according to handbook are 195/70 front 215/65 rear wether 2wd or 4wd.
David Edwards wrote:I have been running on 215's all round since I bought it, no probs, just remember the speedo will probably do what mine does,lol, record 5mph faster than you are actually doing, I am not bothered about it as it helps with speed limits,lol.
Thanks guys
215 it is (ps I'll check the speed against a sat nav when they are fitted).
Mountain
Post by Mountain » Tue Mar 16, 2010 10:04 pm
My Bongo came in from the Land of the Rising Sun with 195/80/15 mud and snow tyres on.
They are very 'bouncy'!
Now I've got me some alloys and I have got hold of some 205/70/15s
Anyone got this size? They work out around a 1% greater circumference that standards......but they are new and very cheap!
Oh alloys! What do you think?
You've Been Bongod
Post by You've Been Bongod » Tue Mar 16, 2010 10:54 pm
are the alloys off a mitsubushi fto??
dont forget to get alloy wheel bolts as steel wheel bolts will not do the job due to the way the bolt fits upto the wheel
Mountain
Post by Mountain » Wed Mar 17, 2010 12:29 am
Dunno :oops:
Advertised as Mitsubishi alloys...£75 :shock:
rita
Post by rita » Wed Mar 17, 2010 11:24 am
Mountain wrote:Hi,
Hi,do you have centre caps for your alloys?
Alison01326
Post by Alison01326 » Wed Mar 17, 2010 1:46 pm
Being a bit thick here but if your speedo reads fast (ours does, a bit) does that mean your odometer is wrong too?
Ours seems to be OK, but have only ever really checked it on short runs. I imagine the further you go the more obvious it would be.
It's been checked with a hand held GPS unit (don't have proper sat nav) but that's not why I am being thick :roll: :oops:
Alison
Post by missfixit70 » Wed Mar 17, 2010 2:01 pm
Alison01326 wrote:Being a bit thick here but if your speedo reads fast (ours does, a bit) does that mean your odometer is wrong too?
Could be, best to check it over a long journey & see what sort of % difference you get between measured & actual.
