bleeding frustration....heater controls
wonkanoby
Post by wonkanoby » Fri Mar 19, 2010 6:49 pm
spent 45 minutes refilling and bleeding her
just got to point were temp gauge was at 1.pm and she runs out of diesel
but at that point front heater was still blowing cold
rear would cook you
looking under neath at the round thing
you can see the bits moving as you cycle through the settings
but when you mess with temp on it you see nothing
or am i looking in the wrong place
wonkanoby
Re: bleeding frustration....heater controls
Post by wonkanoby » Fri Mar 19, 2010 9:31 pm
ok the temp control appears to be on passenger side
it moves but the rod seems an odd shape so i wonder if its not moving far enough
my main question now is what needs removing so i can get to touch the heater rad
to see if its getting hot or not
and if its not is there a faq on removing it
Post by missfixit70 » Fri Mar 19, 2010 10:37 pm
This should point you at all you need http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727
widdowson2008
Post by widdowson2008 » Fri Mar 19, 2010 10:40 pm
For comparrison, heres a pic of my temp control (passenger side) and this works fine. Is yours something similar?
Steve
wonkanoby
Post by wonkanoby » Sun Mar 21, 2010 10:56 am
yes and with arm level like thats supposed to be max heat
the rads hot i removed the 2 screw and teased panel below and can touch it
so im lost must be the gubbins this arm moves
but i cannot see how to get a look at it
without stripping the car down
Post by missfixit70 » Sun Mar 21, 2010 3:50 pm
Did the links on the FAQ not help at all? are you sure the heater matrix is getting hot? could be blocked or just airlocked? what method are using to bleed?
wonkanoby
Post by wonkanoby » Sun Mar 21, 2010 4:06 pm
hot enough to burn my finger tips if left to long
same method of rev and idle and keeping topped up ive allways used as the faq basically
seems by feel its a plastic one is that right
