Rear motor & fan, doesn't look like it'll go straight in the front, but I'm sure with a bit of firkling it could do the job, bonus being, it lives inside the bongo & is not exposed to all the moisture the front one is, doesn't tend to get used as much either, so, if it can be made to fit, it'd be a reasonable source of good fan motors for the front from scrappers or converters.
Rear heater control module, slightly different code on it but it looked the same size & has the same 3 pin connection, so I tried it, works fine on all speeds
The actuators for mode & heater flaps look to be the same too (2 of them in the rear)
ZEXEL 502752-1310
56624 12V
The only thing that may be different is the spindle bits that clip onto the actuators, but they just clip out.
I haven't checked to see if any of the rods & clips are the same yet.
There were a couple of relays in there too, I think at least one of them looks very similar to the ones for the lights on the inside of the passenger wing & were rated the same ( I took these off ages ago, I've forgotten details).
