I will try and explain My issue the best I can.
I have recently Had the head replaced on the Bongo.
I have a slight worry even though the van is running really well and much lower on the temp gauge.
My coolant alarm keeps coming on about every fortnight. I top up with coolant and its fine for about the same lenght of time. At first I was very cautious, but have now noticed that the alarm will stop after driving for a few miles. ( I guess thats down to the water expanding?)
After the van had cooled today I used a thick cable tie to dip the expansion tank and found the level to be above the lower sensor screw on the tank. Despite this the alarm still stays on when the van is started.
The other thing I have noticed is that when I open the cap on the expansion tank there is a good bit of pressure in it. This is after the bongo has been on stop all day.
I guess a trip back to the garage is needed, but just wanted your thoughts on this please.
I should add that the mechanic is experienced with bongos.
Thanks for your help,
Mike.
