lights warning beeper
jimbob88
hi guys another one from me,
just wondered if the bongos normally have a beeper to remind of lights being left on cos i think myneighbours getting bored of telling me my lights have been left on
my friend had one on his old one but mine dont seem to
any ideas
many thanks
any ideas
many thanks
Re: lights warning beeper
Yes they do have one, but lots of people disconnect them. There's loads on here if you do a search
- daveblueozzie
Does your bongo beep when put in reverse, and when you leave your keys in, if not its probably been unplugged, its under the panel at the side of your right leg at the side of the door its either a blue or green box depending on the bongo.jimbob88 wrote:hi guys another one from me,
any ideas
many thanks
Lost without my Bongo.
jimbob88
thanks went out plugged it back in and jobs a gooden
just gotta figure out which one is for the reverse cos keys and lights is all i want
many thanks for the help,
james
james
- dreamwarrioruk
drop the little cover under the steering wheel. just to the left you will find a white connection block, right near to a bigger block connection. think theres only 2 wires going to it. unplug that and you will still have lights on bleep, but not the one that bleeps with the keys in and door open. reverse bleep will only work with the lights on.
hope that helps in a vague way.
mike, jo and emma
- missfixit70
Depends on the age of your bongo - http://www.igmaynard.co.uk/bongo/forum/ ... ep#p395504
- dreamwarrioruk
jimbob88
what you guys dont know aint worth knowing,
thanks once again
thanks once again
- dreamwarrioruk
how olds the bongo then to put me out of my misery if i was psychic and got it right
mike, jo and emma
jimbob88
its a 1995 4wd 2.5td tin top
how do you feel now
how do you feel now
- dreamwarrioruk
jimbob88
i love being right,
come to think of it , its a guy thing
I got no problems with the beeps..
But i had thought about fitting a latching switch in-line to disable it, cuz they don't half spoil the peace on a campsite!!
Out of respect, i like to keep the noise to a minimum when pitching up at a funeral too!
- daveblueozzie
All i did was cut the white wire on the connector at the side of the door, no beeps for keys, everything else works.
jimbob88 wrote:![]()
i love being right,
