Hi.. Unfortunatly smelled that used coolant smell recently and found that my bongo radiator was weeping slightly at the very top of the radiator when engine warm.. ALL the way across the top of the fins its damp but only dripping from one spot.... Only small amount is dripping but needs attention..
Are re-con of the radiator pricey or is it just easier to buy a new one??
I am in Australia and as there is HARDLY ANY bongos here im wondering if anyone can give me a DEFINATE replacement to match up that is the same as the Bongo??
eunos,323, B2500 ute, 626, Ford ranger etc??
Radiator LEAK
Radiator LEAK
Racing green with extras!!Self build full side conversion which rocks!!!
- helen&tony
Re: Radiator LEAK
I am sure that there are some good shippers who can get a rad to you...maybe order direct from Japan...I know a lot of e-bay sellers ship world-wide...I use international quite a lot, and I can't remember how much carriage was...they aren't that heavy.
If you try a Ford Ranger one, check to see if it has the oil cooler for the transmission on the bottom...it may not have
- mikexgough
Re: Radiator LEAK
If you can get one shipped from the UK..... These Guys have direct replacements that are O.E yet 1/2 the cost
- helen&tony
Re: Radiator LEAK
I'll go with Mike on that one...try them...they ship here!
Re: Radiator LEAK
ALl good..self repair..lol.. got recomended this stuff i think it was called silverseal... its is from America and is in a very small cylinder tube about 2 inches high..Its like gun powder..LOL.. apparnetly used in heavy vehicles for a PERMINENT SEAL..
works a TREAT, no leaks totally gone..we will see how she goes..
Re: Radiator LEAK
Be careful using a rad sealer, in most cases the old bongo rads seem to bung up n cause overheating so keep an eye on that temp guage. Had a rad weep n pop on me just last sat night on the way out!! started as a tiny weep on the top which i noticed 5 mins beforei left and thought, i'll drop a new rad in first thing monday! typical!!
Julian
Julian
Re: Radiator LEAK
there availible on trademe in NZ
http://www.trademe.co.nz/Trade-Me-Motor ... 304313.htm
