where can i buy a Diesel Fuel injection pump 1996
tomheaney99
Post by tomheaney99 » Tue Apr 13, 2010 9:55 am
The garage has said air is coming into the the pump sumwhere so says rather than doing diagnostics to find what's causing it on the pump. May be cheaper to get a used pump. Anyone know where to get them from that aint over priced?
tom :)
wonkanoby
Re: where can i buy a Diesel Fuel injection pump 1996
Post by wonkanoby » Tue Apr 13, 2010 10:00 am
have you tried a pm to those listed in breaking bongos
The Great Pretender
Post by The Great Pretender » Tue Apr 13, 2010 10:15 am
If the problem is at the pump the front seal is the usual culprit. Personally I would take the Bongo to a pump specialist. Air can be drawn into the pump from connections downstream from the pump so a replacement may not resolve your problem.
To infinity and beyond
tomheaney99
Post by tomheaney99 » Tue Apr 13, 2010 12:09 pm
fair point matey.
They garage attatched clear fuel pipes to look for air?
Air was going from the pump back to the tank? but not going into the pump?
The seals easy to change?
final question :)
If the pump does need to come off. The garage said that they'd recommend replacing the cam belt as they would have to adjust it etc. Is this correct?
tom.
The Great Pretender
Post by The Great Pretender » Tue Apr 13, 2010 1:39 pm
Front seal is behind the drive pulley, new belt needed. :wink:
tomheaney99
Post by tomheaney99 » Tue Apr 13, 2010 2:01 pm
thanks for heads up :)
Simon Jones
Post by Simon Jones » Tue Apr 13, 2010 2:36 pm
Tom, PM sent :)
