Complete list of all the Bongo hoses
Main cooling system -
15-261 - bypass/recirc into top of thermostat
15-381 - bleed hose
15-186 - top hose/engine outlet to large metal pipe drivers side
15-183 - Large metal pipe drivers side to top of rad (inlet)
15-184 - bottom of rad/outlet passenger side to large metal pipe passy side
15-185 - passy side large metal pipe to bottom of thermostat
15-227 - top of rad to header/expansion tank
15-188 - expansion/header tank to heater return pipe
Most of front & rear heater system -
61-211 - drivers side heater pipe to front heater matrix
61-212 - front heater matrix to heater return pipe
61-214 - heater return pipe to thermostat
61-213 - outlet over starter on engine, drivers side to heater pipe
61-211A - drivers side heater supply pipe to rear heater matrix
Rear heater return -
61-212C - rear heater matrix to return pipe behind engine
Another rear heater return -
http://www.lushprojects.com/bongopartsm ... 1of02.html
61-213A - rear heater return pipe connector behind turbo under passy seat
Two turbo cooling hoses -
13-539A &
13-546 - turbo suppply & return hoses
Makes 17 by my count. I think it's all right, let me know if there're any errors, off to depressurise my brain now.
Anybody deletes this post will be killed - not doing all that again
