A stud is broke on the section going from exhaust to the engine itself. Due to exhaust fumes escaping I am going to get the gasket replaced when the nut gets changed. which out of these two do i need?
Bongo 2.5td 1996.
If it's the exhaust manifold stud, you'll need the exhaust manifold, t'other one is for the air inlet on t'other side (does what it says on the tin )
You may well find that the exhaust manifold is warped too.
