speedo chip removal
tezzer22
speedo chip removal
Post by tezzer22 » Tue Apr 27, 2010 8:00 pm
hi , iv been having intermitant problems with my gearbox going into hold mode ie locked in a high gear this is rectefied by turning the ignition off and restarting then all is well again for a while , iv had the car pluged in to a fault reader but there was nothing , it has been sugested that the speedo chip can sometimes cause problems so i have decided to remove the chip for a while to see what happens , i have removed the chip but the speedo is not working at all now altho the van drives fine, is there something i should have refited when i removed the chip ?
westonwarrior
Re: speedo chip removal
Post by westonwarrior » Tue Apr 27, 2010 8:03 pm
a wire is cut for instation of the chip that needs reconnecting
kawasaki kid
Post by kawasaki kid » Tue Apr 27, 2010 8:08 pm
It may sound daft but have you made sure that all the original wires have been properly rejoined to each other to make the circuit. I ask this as the wiring is thin to start with. :)
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
tezzer22
Post by tezzer22 » Tue Apr 27, 2010 8:16 pm
weston you are correct i have not reconected the kmh signal input wire , that might help
thanks
westonwarrior
Post by westonwarrior » Tue Apr 27, 2010 9:21 pm
glad I could help
Mine should have said instalation :oops: and thats probably still wrong
