switches
baronweetman
switches
Post by baronweetman » Fri Apr 30, 2010 6:41 pm
Not another switch question. :lol: I hear
Well I have a switch located between the two blind switches and it shows a small fog type lamp with the A/B beside it. can't figure what it's for. The mechanic says it could be a fuel heater which should only work at a certain temp. Any ideas?? If it is indeed a fuel tank heater. How can I tell if it works and will it be suffic ient to heat veg oil??
[b]la connaissance exacte du passé, en éclairant le présent, vous permettra d'agir sur l'avenir[/b]
baronweetman
Re: switches
Post by baronweetman » Fri Apr 30, 2010 6:43 pm
meant to say the mechanic said a fuel tank heater should only work when the outside temp dropped below a certain level
Re: switches
Post by missfixit70 » Fri Apr 30, 2010 8:45 pm
Spolights that're (or were) mounted on the bullbars.
baronweetman
Re: switches
Post by baronweetman » Fri Apr 30, 2010 8:54 pm
Thanx Kirsty I guess you are unfortunately right. Was kinda hoping that it was a heater. Only had my new spots wired in last week and they are wired to come on with main beam. I remember when I bought Blodwen Steve at Outback said the previous owner had taken his spots with him. Have to have another look at thinning my oil out in winter.
mister munkey
Re: switches
Post by mister munkey » Fri Apr 30, 2010 8:55 pm
The regular A/B switch is , as MissFixit says, for spots/fogs.
Have you tried an accurate understanding of the past, to clarify the present, it allows you to act for the future?.
baronweetman
Re: switches
Post by baronweetman » Sat May 01, 2010 8:40 am
:lol:
maxheadroom
Re: switches
Post by maxheadroom » Sat May 01, 2010 9:16 am
This is what I have used my A&B switch for.........
http://www.igmaynard.co.uk/bongo/forum/ ... &hilit=fog
Keep the Faith
dobby
Re: switches
Post by dobby » Sat May 01, 2010 12:15 pm
mister munkey wrote:The regular A/B switch is , as MissFixit says, for spots/fogs.
Ah but the past is history, the future is a mystery but the present is a gift!
