Courtesy light
daveblueozzie
Courtesy light
Post by daveblueozzie » Sun May 02, 2010 12:24 am
Has anybody fitted a courtesy light delay on the bongo, i think its called theatre lights, it leaves the interior cab light on for a few seconds when you get in after closing the door.
If you have where did you get the unit and was it easy to fit.
I remember years ago you could get a small unit that fitted on the pin switch and that delayed the lights.
Lost without my Bongo.
dobby
Re: Courtesy light
Post by dobby » Sun May 02, 2010 12:36 am
I remember those, I tried google just now and couldn't find anything. It used to be a little pcb kit etc?
Like this:
http://www.circuitdb.com/circuits/id/196
Scott
Re: Courtesy light
Post by Scott » Sun May 02, 2010 11:38 am
I have just bought a fiesta relay to fit in, you have to watch out as some of them there pin switches just dont work at all!
In the end I opted for one from a ford fiesta, just need to get round to fitting it, you can pick up all the wires from drivers foot well, The good thing about the fiesta one is the ign+ wire that turns the light off when you turn the ignition on :D
http://www.fiestaguides.co.uk/content/m ... delay.html Simple wiring instructions.
The user formerly known as csmcqueen ;)
スコット
Re: Courtesy light
Post by mikeonb4c » Sun May 02, 2010 11:44 am
Can these be made to work with LEDs, fluorescent tubes etc? I have a distant alarm bell going off about that but I'm not sure :roll:
Scott
Re: Courtesy light
Post by Scott » Sun May 02, 2010 12:05 pm
I don't see why not as these are time based and not based on current drawn :D
スコット
dobby
Re: Courtesy light
Post by dobby » Sun May 02, 2010 12:11 pm
csmcqueen wrote:I have just bought a fiesta relay to fit in, you have to watch out as some of them there pin switches just dont work at all!
Nice find!
Re: Courtesy light
Post by mikeonb4c » Sun May 02, 2010 12:14 pm
csmcqueen wrote:I don't see why not as these are time based and not based on current drawn :D
Ah! It was Dave calling them 'theatre lights', and my memory of theatre lights being lights that faded (also seeing lights in posh cars that did that), that set the alarm bells off. Am I right in saying that LEDs, fluorescent tubes etc. won't work with dimmers? I think that is what I was trying to ascertain.
Re: Courtesy light
Post by g8dhe » Sun May 02, 2010 12:17 pm
mikeonb4c wrote:Am I right in saying that LEDs, fluorescent tubes etc. won't work with dimmers?
Yes in general that's right, its not that they can't be dimmed but simply increasing the resistance / reducing the current won't work for most modern lighting systems as it does with filament bulbs.
Re: Courtesy light
Post by missfixit70 » Sun May 02, 2010 6:17 pm
I recall someone doing it a while back, can't remember who, have a play with searches & it should come up.
Lewy
Re: Courtesy light
Post by Lewy » Sun May 02, 2010 7:59 pm
I fitted one a few years ago - I'm sure I got it from Ebay following a tip from on here. It solders easily into the wiring in the courtesy light itself and there is a tiny dial to alter the time the light stays on after the door has shut, then fades slowly.
It does mean that the door sign and lights on beeper stay on for the lenght the light takes to fade if you open then shut the door with the lights on - but it is a useful mod.
I've trawled through posts but can't find reference to it - sorry
Lewy
Re: Courtesy light
Post by Lewy » Sun May 02, 2010 8:07 pm
Seach under interior - light - delay and you will find the post from 2007 - there was a guy selling them on ebay for a fiver
G'luck
daveblueozzie
Re: Courtesy light
Post by daveblueozzie » Sun May 02, 2010 8:52 pm
I think ive found what im after on tinternet :wink: , just ordered it , will let you know if its ok when fitted.
dandemann8
Re: Courtesy light
Post by dandemann8 » Sun May 02, 2010 9:02 pm
Bongo no more........... ;-(
Re: Courtesy light
Post by bigdaddycain » Mon May 03, 2010 12:50 am
Cheers Dunc, we were after the type that fades the light out as it goes off (it's called theatre lights dimming in my Ford manual) We reckon we've located the gizmo for the job... :wink:
Scott
Re: Courtesy light
Post by Scott » Mon May 03, 2010 12:10 pm
bigdaddycain wrote:Cheers Dunc, we were after the type that fades the light out as it goes off (it's called theatre lights dimming in my Ford manual) We reckon we've located the gizmo for the job... :wink:
If you get the theatre lights to work with LED's let me know, I thought you had to use standard filament bulbs with these?
スコット
