A week or two ago, we replaced the last of the hoses for silicon...the last 5 that had been sitting in a box for a year or two....and there's a tale of caution....First, Tony got to attack the rear heater,,,,and broke a bit off one of the stubs going into the heater matrix....PLASTIC, of all things!!!...so , naturally, I called him every name under the sun....when I calmed down, I re-fitted them myself...crikey...talk about brittle!!!....So, we completely drained the system again (did it last year ...TWICE...once when we fitted a new Rad. and the other time just to fit some hoses, and check the coolant)....
So, we bled it the other week....and went for a wee spin...next morning, a cold bleed....everything functioning well
Quick...out with all the heater components...10 minute job....mmmm....where's the leak....eventually traced to one of the front heater matrix stubs....."Oh, dear", said I
So...there's a tale for you if you intend to replace the hoses....have a spare piece of plastic of the right external diameter to bond over the metal stub if yours cracks....some plumbing pipe looks like a fit!
But WHY???? does Mazda...a reputable car manufacturer use ridiculous plastic components in the cooling system....I replaced the radiator with all-metal!...proper stuff!
