Engine running on a bit when I switch ignition off
Alison01326
Re: Engine running on a bit when I switch ignition off
Post by Alison01326 » Thu May 13, 2010 7:20 pm
dunslair wrote:Theres nowt rang wi a man who wears a skirt lassie :!: :wink: :lol: :lol:
... or a lacy blouse :wink: :lol:
Alison
Alison01326
Post by Alison01326 » Thu May 13, 2010 7:26 pm
Thanks for all your advice, peeps! I've had a little feel and the solenoid is not loose or wobbly and the wire seems OK. I'm reluctant to take it out altogether for a look at the rubber seal as it looks like a fiddly old job with other bits to remove which are in the way. With interruptions it will probably take me far longer than it should and I'll probably need to be somewhere while there's bits of Bongo lying around on the pavement. So I shall get a professional to attend to the job in the not too distant future when it's service time.
Anyway, I tried to tighten it and it is already nice and tight, and when I went out afterwards the engine stopped at the right time. I went out again later and it was overrunning again, so I suspect the solenoid or its rubber seal does indeed need replacing and hope I can get away with it for another few weeks. I have ordered a £9.99 solenoid anyway, so it's here in the event of an emergency. .
Alison
rita
Post by rita » Thu May 13, 2010 7:51 pm
Alba gu bra
Alison01326
Post by Alison01326 » Thu May 13, 2010 7:54 pm
rita wrote:Alba gu bra
Kernow bys vyken (it's the Cornish Hunting Tartan :wink: )
Alison
mikexgough
Post by mikexgough » Thu May 13, 2010 7:59 pm
Looks like a Kilt gathering at the Bash is on the cards.....
Alison01326
Post by Alison01326 » Thu May 13, 2010 8:02 pm
My two chaps rent a kilt when the need arises and believe it or not, it costs the same for a little one as it does for a big one. I suppose kilts at the Bash could be an option. Might start up a "who's got a tartan" thread (better than asking who wears a kilt - could get dodgy :lol: )
So, here I am with a potential fuel stop solenoid issue discussing kilts. What am I like [-X
Alison
mikexgough
Post by mikexgough » Thu May 13, 2010 8:06 pm
I can bring mine along..... happy to wear it too.... not all the formal gear....just casual wear.... My Tartan is McNaughton
rita
Post by rita » Thu May 13, 2010 8:37 pm
mikexgough wrote:I can bring mine along..... happy to wear it too.... not all the formal gear....just casual wear.... My Tartan is McNaughton
The main thing is,,,,
What do you wear under the kilt :D
mikexgough
Post by mikexgough » Thu May 13, 2010 8:41 pm
Nothing worn.....It's all in good order...
rita
Post by rita » Thu May 13, 2010 8:48 pm
Alba gu bra
mikexgough
Post by mikexgough » Thu May 13, 2010 8:51 pm
Alison01326
Post by Alison01326 » Thu May 13, 2010 9:40 pm
This is one of the more interesting diversions that a post has made :wink:
One hopes that it will be far too hot in June for you chaps to cope with kilts. I have seen t shirts worn with kilts but never crocs nor sandals. Neither do I want to :lol: And don't bring your kilt to Cornwall when you bring the rain, Mike - I dread to think how heavy a wet kilt must be :-"
Alison
mikexgough
Post by mikexgough » Thu May 13, 2010 9:45 pm
Alison01326 wrote:don't bring your kilt to Cornwall when you bring the rain, Mike
The Rain always seems to greet me when down your way..... and at the same time it's dry up here in the Angles..... hedging my bets this year with Bodmin in August.....
Alison01326
Post by Alison01326 » Thu May 13, 2010 9:51 pm
No further comment 8)
Alison
Post by Bob » Thu May 13, 2010 11:26 pm
Mrs B is of the Munro Clan and will doubtless be very pleased with a Celtic Gathering. :D
