mason alarm and resister ????
bobngo
Post by bobngo » Mon May 17, 2010 10:18 pm
i am about to fit a mason alarm, and since the dash will be "out" .i was wondering if i should also fit the 120 ohm resister as well, so it would be belt and bracers or would that mess everything up ???
Re: mason alarm and resister ????
Post by missfixit70 » Mon May 17, 2010 10:25 pm
I'm guessing it'll get a bit confused as you'll effectively be putting the resistor in parallel with the Mason I think. Why would you want to do both anyway, what benfit will it bring? the Mason does what it does, sensitises the gauge & provides a settable alarm, the resistor mod just sensitizes the gauge, Fit one or the other, but not both.
mister munkey
Post by mister munkey » Mon May 17, 2010 10:35 pm
Agreed.
The resistor approach is an alternative to the Mason.
Can't fathom what the system would make of both . . . .
mikexgough
Post by mikexgough » Tue May 18, 2010 7:30 am
It's your call .....either one does the job...... on a personal note..... I would go for the Mason
bobngo
Post by bobngo » Tue May 18, 2010 7:46 am
thanks everyone ,mason it is then !!!!!
