Lost all our coolant
bongomadness
Post by bongomadness » Mon May 31, 2010 5:48 pm
Went to drop son off this afternoon and when he got out of the van he heard water................i got out and in the middle underneath there is a big metal pipe with a rubber hose on each end squirting hot water out!!!!! :( Its the pipe that runs near the big housing. needless to say i wish i had a coolant alarm but that said it has to be fixed before August. Ive got a mechanic just need to source the right pipe and hoses. Can i get them from bongo fury or mazda itself ???
HELP PLEASE
the janner vanner
Re: Lost all our coolant
Post by the janner vanner » Mon May 31, 2010 5:50 pm
try Bongobits 01752 250777
The Janner Vanner
bongomadness
Post by bongomadness » Mon May 31, 2010 5:54 pm
thanks will give em a bell :) Forgot to say there was no sign of any leaks or water under the van prior to this............it just happened just like that.Am glad i was local and got to get van home where she will stay now until she is sorted.BUMMER!!!! on the bright side i am not without transport.i get use of hubbies vtec prelude for a while!! Much prefer the Bongo though :D
maxheadroom
Post by maxheadroom » Mon May 31, 2010 6:01 pm
Keep the Faith
bongomadness
Post by bongomadness » Mon May 31, 2010 6:10 pm
It could be Max. will just go out and have a quick look brb
haydn callow
Post by haydn callow » Mon May 31, 2010 6:19 pm
it's the top hose "top of rad to cylinder head (under drivers seat)"
It starts with a rubber hose.....Rad to metal pipe
then metal pipe
Then rubber hose metal pipe to cylinder head.
Put all 3 together and you have the complete top hose system
Did the tempreture gauge move towards HOT ??
http://www.coolantalarm.co.uk
Also BMW Clocks
bongomadness
Post by bongomadness » Mon May 31, 2010 6:24 pm
then metal pipe
It is all them Hayden. Unfortunately it did rise to nearly hot. Do you think any damage is done..........
bongomadness
Post by bongomadness » Mon May 31, 2010 6:26 pm
is it one of these...
thanks Max for that
bongomadness
Post by bongomadness » Tue Jun 01, 2010 9:58 am
Now i know which hoses to get i am thinking maybe renew all the pipes top and bottom.......and fit a coolant alarm. It looks like the hoses are perished and would rather spend the money renewing it all as i dare say they are all the originals on the van.Looked on the cooling system diagram and i can see the top,bottom and a spaghetti of others. If you read this hayden could you advise is it 3 for the top (1 metal 2 rubber) andsame for bottom hoses please
I hope no damage was done to the head as temp guage rose to a cm before hot but i drove with heater on full wack on cold to try and keep it cool and also filled up res bottle for what it was worth. I am absolutely gutted.
haydn callow
Post by haydn callow » Tue Jun 01, 2010 11:24 am
Yes...bottom hose is also 2 x rubber and a metal pipe...there are also another 10/15 small bore pipes
Also BMW Clocks
bongomadness
Post by bongomadness » Tue Jun 01, 2010 11:31 am
That sounds a lot of pipes or have i gone blonde and you mean the bores ???
bongomadness
Post by bongomadness » Tue Jun 01, 2010 11:36 am
Told you i was dim lol my god there are a lot of pipes in the system :( would it be best to do all of them do you think?????
haydn callow
Post by haydn callow » Tue Jun 01, 2010 11:56 am
personally I would just check them all and replace as required......
Also BMW Clocks
Post by missfixit70 » Tue Jun 01, 2010 12:12 pm
Complete list of hoses, 17 in all on a diesel, numbers are drawing numbers, part numbers can be got from the drawings by clicking on the + symbol on the description on the left,
Main cooling system - http://www.lushprojects.com/bongopartsm ... mgno=.html
15-261 - bypass/recirc into top of thermostat
15-381 - bleed hose
15-186 - top hose/engine outlet to large metal pipe drivers side
15-183 - Large metal pipe drivers side to top of rad (inlet)
15-184 - bottom of rad/outlet passenger side to large metal pipe passy side
15-185 - passy side large metal pipe to bottom of thermostat
15-227 - top of rad to header/expansion tank
15-188 - expansion/header tank to heater return pipe
Most of front & rear heater system - http://www.lushprojects.com/bongopartsm ... mgno=.html
61-211 - drivers side heater pipe to front heater matrix
61-212 - front heater matrix to heater return pipe
61-214 - heater return pipe to thermostat
61-213 - outlet over starter on engine, drivers side to heater pipe
61-211A - drivers side heater supply pipe to rear heater matrix
Rear heater return - http://www.lushprojects.com/bongopartsm ... mgno=.html
61-212C - rear heater matrix to return pipe behind engine
Another rear heater return - http://www.lushprojects.com/bongopartsm ... 1of02.html
61-213A - rear heater return pipe connector behind turbo under passy seat
Two turbo cooling hoses - http://www.lushprojects.com/bongopartsm ... mgno=.html
13-539A &
13-546 - turbo suppply & return hoses
Post by Northern Bongolow » Tue Jun 01, 2010 12:17 pm
from my experience if your hoses start to go,this indicates that the stat is not doing its job properly,sorry but just something else to look at.
