http://www.igmaynard.co.uk/bongo/forum/ ... &start=240
The test Bongo
The cooling system has been refurbished as near as possible to the original spec. apart from the gauges added for tests.
New main radiator, all new hoses, new Mazda thermostat, heater matrix (2nd hand), rear heater motor (2nd hand)
Also, during refurbishment, the cooling system has been drained and re-filled 5 times.
The object of this excercise is to find out which section of the cooling system is in control and at what stage (temperatures) control is passed on to the next part of the system.
We had a problem from the start because Bulgaria, where the system is being tested, has strict speed restrictions so 'gunning' the engine to raise temperatures is not an option. To overcome this, the next stage of data collection will be powering up hills which should get temperatures a little more elevated. If that fails to get results, then plan 'B' kicks in - FILL THE BONGO WITH FAT LADIES and repeat the hill climb.
The results of the first set of data are shown on the graph below. This data was collected running at speeds up to 90 kph (56mph) and max engine speed of 3000 rpm. Bongo not even broken into a sweat and thermostat remaining closed. The upper radiator appears to have the control of the cooling system at this stage.
One thing that has come as a bit of a surprise (to me at least) is that the heater supply is LOWER in temperature than the heater return. I expected it to be the other way round.
graph amended - ambient added
Roll on the FAT LADY TESTS
More to follow when available.
