has any body got a list of rev/speeds at which the gearbox should change up, wife keeps asking why i keep waving my left hand around near the cubby hole
many thanks
ps first time on a long run this afternoon since getting it. very nervous.
Good question(s) - been wondering the same myself so will be very interested in replies.Darkstar wrote:
has any body got a list of rev/speeds at which the gearbox should change up, .......also how many gears does it have......?
scanner wrote:That depends on how deep your foot is buried in the carpet.
The possibilities are infinite and the auto box decides when and if depending on your requirement (throttle position) and load (uphill, downhill, laden, unladen - etc.)
Mine will go into lock-up top at 37mph/1500rpm pootling around gently or at 70+ at 4000rpm if booting it uphill away from a roundabout.
But what's "normal"?Darkstar wrote:scanner wrote:That depends on how deep your foot is buried in the carpet.
appreciate the foot to the floor syndrome, just wanted to know under normal driving conditions,
It will change into 4th, but the torque converter won't lock up until it's warm.Mickymouse wrote:The auto box has 4 gears not 3. It will not change up to 4th. until it is warmed up,maybe about 10 minutes.
Mick
Mickymouse is correct, they will not command 4th until the engine (not the gearbox) has got to a certain temp, it then has to get a little warmer to get the l/up to function.scanner wrote:It will change into 4th, but the torque converter won't lock up until it's warm.Mickymouse wrote:The auto box has 4 gears not 3. It will not change up to 4th. until it is warmed up,maybe about 10 minutes.
Mick
Mine appears to have changed up into 4th quite a while before it finally locks up in top and doesn't seem to need to warm up much to do it. This time of year it is locking up within about a mile of starting off from cold.Alacrity wrote:Mickymouse is correct, they will not command 4th until the engine (not the gearbox) has got to a certain temp, it then has to get a little warmer to get the l/up to function.scanner wrote:It will change into 4th, but the torque converter won't lock up until it's warm.Mickymouse wrote:The auto box has 4 gears not 3. It will not change up to 4th. until it is warmed up,maybe about 10 minutes.
Mick
As stated the gearbox has 4 gears & it also has a lock up clutch in the torque converter (to prevent overheating & to aid fuel economy), It will select 3rd on a light throttle (normal town driving) below 30 & top at about 37. Lock up will come in a little later & feels like another (5th) gear (it isn't). At any point between light throttle & flat out the changes are infinitely variable as it depends on throttle position & road speed.
Thats right, 1, 2 & 3 only unless you get over 37mph(ish)Darkstar wrote:so basically it will never go into top gear around town (30mph), i guess i get used to it along with the roll and how far to press the pedal out of roundabouts, have'nt got the hang of that yet, at least my left legs stop reaching for the clutch
