Brass ring
Bigcol
Brass ring
Post by Bigcol » Mon Jul 05, 2010 3:25 pm
My horn has packed up and the airbag light is flashing away. Typically MOT is around the corner. An auto-spark who has experience of Bongo's has suggested there is a brass ring behind the steering wheel that will need replacing. Any idea's on where to source one?
321Away
Re: Brass ring
Post by 321Away » Tue Jul 06, 2010 12:48 pm
unlikely to be a brass ring, its a compact unit that has a ribbon cable wound in it and bursts out like a clock spring if opened, changed 1 the other day. if you cant get replacememnt in time get the electrician to fit a push switch after the steering wheel for the horn, airbags arent part of the MOT anyway.
Julian
Re: Brass ring
Post by missfixit70 » Tue Jul 06, 2010 4:48 pm
321Away wrote:unlikely to be a brass ring, its a compact unit that has a ribbon cable wound in it and bursts out like a clock spring if opened, changed 1 the other day. if you cant get replacememnt in time get the electrician to fit a push switch after the steering wheel for the horn, airbags arent part of the MOT anyway.
Julian
& they're probably past their safe "use by" date anyway.
Bigcol
Re: Brass ring
Post by Bigcol » Tue Jul 06, 2010 11:24 pm
Cheers dudes.
Re: Brass ring
Post by Bob » Tue Jul 06, 2010 11:38 pm
Good point, the horn doesn't have to use the original switch, it just has to work.
Don't forget to show the tester where the new switch is fitted to avoid a fail. :)
