leisure battery
tommywelly
leisure battery
Post by tommywelly » Wed Jul 07, 2010 7:59 pm
Which leisure battery should I get to fit the tray in my Bongo the tray is 31cm long
You've Been Bongod
Re: leisure battery
Post by You've Been Bongod » Wed Jul 07, 2010 8:09 pm
i have a marine battery 110amp fits perfect in willinton tray and has never let me down
scanner
Re: leisure battery
Post by scanner » Wed Jul 07, 2010 8:15 pm
tommywelly wrote:Which leisure battery should I get to fit the tray in my Bongo the tray is 31cm long
Err................. one that is less than 31cm long and low enough to fit under the bonnet? :wink:
Seriously you will have to go somewhere that has some in stock and see which one fits.
If it is a "Willinton" tray that will be a 110amp Numax.
mikexgough
Re: leisure battery
Post by mikexgough » Wed Jul 07, 2010 8:19 pm
yep Wetline Brand...... Marine/Leisure 110Ah...... for me too....again a Willinton Tray....2nd season.....has 3 year g'tee so I expect to change after next season.......my Fridge has been running constant since January.....battery still fine using the Willinton daily and a quick Aldi Battery charger for monthly top ups
MMM did a recent test on Leisure batteries (they even cut them up) One so called Premium make with a long guarantee...... 100 Ah only battery was found to hold only 54 Ah... [-X [-X
The best brand they found was the Banner Energy Bull...... 110Ah put out 122Ah.... =D> =D> Some of the batteries had filler sections to fill out the cell chambers.... [-X [-X
I guess some of the well known brands like Banner/Numax/Wetline etc are the best to go for
tommywelly
Re: leisure battery
Post by tommywelly » Wed Jul 07, 2010 8:38 pm
You've Been Bongod wrote:i have a marine battery 110amp fits perfect in willinton tray and has never let me down
What are the dimentios of the battery ,I don't know if my tray is willington
Re: leisure battery
Post by g8dhe » Wed Jul 07, 2010 8:43 pm
It suggests here http://www.leisurebatteryshop.co.uk/Num ... -Batteries that Numax have replaced the 110AmpHr battery with a 95 AmpHr battery, and it doesn't appear on the Numax brochers at all http://www.manbat.co.uk/cm/files/assets ... isure2.pdf
mikexgough
Re: leisure battery
Post by mikexgough » Sun Jul 11, 2010 8:04 am
Yuasa do a 115 Ah that will fit the Willinton tray..... :wink:
daveblueozzie
Re: leisure battery
Post by daveblueozzie » Sun Jul 11, 2010 8:51 am
If the battery tray is metal then a 110 wont fit unless you alter the tray slightly,(i think you have to bend the lip of the tray flat)
If it looks like a plastic/fibreglass battery tray then the 110 will fit (but its a bit snug) mine is a 110 Bosch battery.
Lost without my Bongo.
