Engine Oil
- The_Gordons
Engine Oil
Apologies if this has been covered before but I couldn't find an answer when I did a search. Can anyone recommend a 10W30 oil for use with the 2.5 turbo diesel engine and where to get it online?
I noticed that members can now get a 10% with Opie Oils and they have the following 10W30 oil:
Motul 4000 £19.79
Amsoil Synthetic £50.84
Redline Synthetic £49.26
I looked at the spec sheet for the Motul 4000 and it has API CF approval which can be used in place of a API CD oil which is the recommended oil on the lubricants fact sheet but no mention if it is suitable for use with a turbo.
Paul
Motul 4000 £19.79
Paul
Bongo replaced by Wellhouse Terrier
Re: Engine Oil
5W/30 is the recommended grade of oil
Quick search of forum comes up with http://www.igmaynard.co.uk/bongo/forum/ ... =oil+grade
- mikexgough
Re: Engine Oil
The Japs also use a CF-4 oil....of 10w-30w.....
Re: Engine Oil
i use millars 5w30 xss (semi sythetic)with brill results,and is generally available.
- mikexgough
Re: Engine Oil
The current oil in my Bongo is Wilkinsons 5W/30W Semi Synthetic...... £7.99 per 2 litre bottle......I had none of my usual Fuchs 5w/30w and wasn't travelling near a GSF Car Parts .........
rjf
Re: Engine Oil
I've just purchased 2x10litre 5w30 semi synth oil API CF grade Asda own brand made I believe by Comma for £10 per 5litre
That should be OK for 5000kms
Nippon Tuck
Re: Engine Oil
I read somewhere that 15w 40 was an acceptable alternative for older high milers. Is this wrong?
It's never too late to have a happy childhood.
Re: Engine Oil
Mines on 137,000 miles (not kms) & I wouldn't use it.Nippon Tuck wrote:I read somewhere that 15w 40 was an acceptable alternative for older high milers. Is this wrong?
Dr.Jekyll
Re: Engine Oil
You are not wrong, as you can use that grade. But you will find that due to its higher viscosity, the engine friction will be higher and you will notice a drop in your MPG figures. Best to stick to 10W/30 or lower IMHO.
Re: Engine Oil
You could use any grade, even 20/50, but you wouldn't want to.Dr.Jekyll wrote:You are not wrong, as you can use that grade. But you will find that due to its higher viscosity, the engine friction will be higher and you will notice a drop in your MPG figures. Best to stick to 10W/30 or lower IMHO.
Re: Engine Oil
not familiar with this oil but just check its for diesels,some are for just petrols,some dont do both.rjf wrote:I've just purchased 2x10litre 5w30 semi synth oil API CF grade Asda own brand made I believe by Comma for £10 per 5litre
thedogsbollox
- Tribal Elder
Re: Engine Oil
And how many litres for a service?
- mikexgough
Re: Engine Oil
Oil & Filter....... 6.7 litres........ Just Oil...... 6 Litres..
