smokey exhaust looks blueish
tomheaney99
Post by tomheaney99 » Thu Jul 22, 2010 1:15 pm
hi,
bongo seems quite smokey, ok when cruising however pulling away at roundabouts or increasing revs there seems more than normal amount of smoke. It has a bluey tinge to it however been checking the oil and no obvious loss?
sometimes the turbo doesnt kick in on rare occasions too.
I have had a coolant leak yesterday (a corroded pipe burst) and it is getting changed tomorrow. I did want to change the thermostat but couldnt get one till next week.
any ideas about smokey exhaust? stagges to check?
tom
Re: smokey exhaust looks blueish
Post by Northern Bongolow » Thu Jul 22, 2010 1:24 pm
what oil have you got in it please.
tomheaney99
Post by tomheaney99 » Thu Jul 22, 2010 1:45 pm
no idea mate, the garage did a full service and changed the oil?
tom
tomheaney99
Post by tomheaney99 » Thu Jul 22, 2010 1:54 pm
the garage said it would have been 5w 30?
Post by Northern Bongolow » Thu Jul 22, 2010 2:06 pm
thanks for that.
im just trying to see what peeps are using,and if it chucks up certain faults.
should be good with that in.
Post by missfixit70 » Thu Jul 22, 2010 3:23 pm
I know you said it's blue tinged but could it be the egr not working properly, FAQ here explains all - http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=14463 Blanking plates avaiable from Allans in Plymouth
tomheaney99
Post by tomheaney99 » Sun Jul 25, 2010 5:58 pm
Had the egr blanked off :/
Tripewriter
Post by Tripewriter » Mon Jul 26, 2010 7:53 am
Blue smoke indicates a lack of air therefore incomplete combustion or engine oil entering the combustion cycle
Has the garage used a cheap air filter?
Otherwise the answers get more complex.
However All diesels smoke but sometimes the smoke isn't visible due to atmospheric conditions.
Dont judge the smoke factor at anything other than normal running temp say after half an hour of continuous running, and perhaps get a specialist to give you an opinion.
tomheaney99
Post by tomheaney99 » Sun Aug 08, 2010 9:29 pm
cheers for that :)
ive been looking at it more and it smokes when it revs above 2k revs. the back of the bongo soots up too. and if i do kick down... well theres dark rain clouds form :).
i am now thinking turbo>?
tom
mister munkey
Post by mister munkey » Sun Aug 08, 2010 9:41 pm
Mines had similar symptoms, plus its been getting through about a litre of oil every 1500 miles or so.
Turns out to be worn piston rings.
Post by Northern Bongolow » Sun Aug 08, 2010 9:42 pm
the turbo kicks in at 1900 -2000 revs so maybe your on to it,if it has an internal oil leak then you may be burning a little.
Post by missfixit70 » Sun Aug 08, 2010 10:04 pm
Blue smoke is typical of worn piston rings TBH, but it could be the turbo, chances are it's just more load as you boot it, compression test?
