The steering on our Bongo suddenly became very stiff after reversing off the drive, I suspected low fluid levels and topped it up as it was very low. I checked for leaks and discovered quite a severe leak from the gaitor! Obviously this is just a dust cover so after removing it the fluid poured out all over the drive. I suspect an inner seal has gone within the cylinder as it pours out from the offside.
I have done a search and as a seal kit is £35 and a recon rack is £188 it looks like I will be attempting a seal overhaul on my rack.
Has anyone removed the rack at all? Is it a difficult job?
Anyone got any tips or know where I can get a cheaper recon rack from?
Thanks for any help...
