TGP,The Great Pretender wrote:Mctavish wrote:
As my man said, it's the last line of defence.
What if you inadvertently send some crud down the line during the filter change? The crud would then have an un-interrupted journey into the heart of your fuel pump.
Using that argument, why is there not a filter after the oil filter then?
When I removed my fuel strainer, there was some crud in it that would otherwise have entered the pump or made it to an injector.
What was the 'crud' solids or an emulsification?
What are the benefits to not fitting the fuel strainer? Do you get a performance boost?
If it is clear, none.
I think munroman may have a point with respect to the re-tightening of the banjo assembly. Although I did mine up fairly tight, I think best course of action would be to replace them with new, they're only a few pence.
They can be reused by annealing but better replaced if any doubt as they are under negative pressure at that point.
Mctavish
The oil system is nothing like as delicate as the fuel system, and the recirculatory nature of the oil system means that the oil is expected to deteriorate over time, so a single filter is in place to limit crud issues. The fuel is on a one way journey through the pump then the injectors, both of which are certainly more susceptible to damage if crud gets in there.
The crud in my strainer looked solid, not an emulsion, so it definitely did it's job.
Each to their own
I wonder if the Audi Le Mans team ditch the fuel strainer?
Mctavish
