MAIN BEAM WIRING
ALL PETROL NO HEAD
MAIN BEAM WIRING
1995 DIESEL SGL5: CAN ANYONE OF YOU GOOD PEOPLE TELL ME THE MAIN BEAM WIRE COLOUR? AM PRESENTLY ADDING DRIVING LAMPS TO BULL BARS AND DON'T POSESS TEST LAMP. ASSUMING BLACK IS EARTH ,THEN IT'S EITHER BLUE/WHITE OR GREEN/YELL. YOUR HELP WILL BE MUCH APPRECIATED.
Re: MAIN BEAM WIRING
why are you shouting?
(It's the Blue/White for Main, by the way)
ALL PETROL NO HEAD
CAN'T THANK YOU ENOUGH MY FRIEND, YOUR A GOOD EGG! (I'M DEAF BY THE WAY- HONEST)
- missfixit70
But we aren'tALL PETROL NO HEAD wrote:CAN'T THANK YOU ENOUGH MY FRIEND, YOUR A GOOD EGG! (I'M DEAF BY THE WAY- HONEST)
ALL PETROL NO HEAD
Is that better?
Never underestimate the power of stupid people in large numbers
(conservative central office)
Ahh, a hushed whisper. Much better.
Hope you get the spots wired up OK!
I sunk mine into the bumper like this
Very neat Dave.
tim & angie
- Bongonaut
(It's the Blue/White for Main, by the way)[/quote]
Well ain't that a handy post, ive been meaning to wire in my new driving lights for a while and was wondering the same thing. Is it best to power them via a dedicated feed and relay using the main-beam feed as the actuation signal or can you just whack em straight on the main beam supply?
Tim
Tim
I'd always use an interposing relay for spotlights. You can't guarantee what the max current the main beam wiring is designed for - but more than likely it was for 2x60W. As your spots will be 55 or 60W, you'd be pretty much doubling the current in the main beam switching and wiring.
The cable access through to the dashboard behind the main battery is pretty easy via the big grommet, and there is a decent mounting point for the relay on the front of the slam panel.
tim & angie
- Bongonaut
Thanks for the prompt reply, I'll stick a relay in.dave_aber wrote:I'd always use an interposing relay for spotlights. You can't guarantee what the max current the main beam wiring is designed for - but more than likely it was for 2x60W. As your spots will be 55 or 60W, you'd be pretty much doubling the current in the main beam switching and wiring.
