Good questions Kirsty. Having just given an unqualified "RECOMMENDED" to the ("Bongo-friendly" listed, and forum-recommended) garage I used for a service/coolant change/MOT last week, it's possible I'll have to modify my recommendation this week.missfixit70 wrote:So how did he refill the coolant, did he use a vacuum fill, bleed it using the bleed pipe? or did he just get lucky?hembramacho wrote:He told me that there wasn't anything really complicated about changing the coolant, and the Mazda Bongo isn't unique in having a complex coolant system. Now I must point out that the mechanic is the least arrogant person I know - he's just laid back and knows his cars, including Jap imports.
My point is, if you know your mechanic, and they know their stuff, then trust them to do what they do best.
Andrew
It isn't complicated, as anyone can see from the bleed video (other methods are available) it's just a matter of ensuring no air is left in the system.
I supplied a carefully measured 13 litres of pre-mixed coolant, and was surprised to find a smallish amount left - haven't decanted and measured (yet!) but there could perhaps be getting on for a litre. However, I was assured that the system had been Bongo-bled properly but they don't always take the full 13 litres re-fill - I assumed, perhaps because they don't always easily fully drain in the first place (something I have experienced, with another motor in the distant past). Drove home, 90 miles cross-country, including some very steep Pennine ascents, and finding temperatures normal, with zero change in the expansion tank cold coolant level (still today, after another 100 miles or so, of use), accepted that he had done the job properly.
Yesterday, however, was the first fully dry day here, since getting the van back on Friday, so only then did I shift the conversion-reversed rear seat out of the way to have a look in the motor:
SHOCK! HORROR! The bleed pipe was detached and removed by me a couple of months back, after a rear heater matrix failure and by-pass, and I used a particularly wide cable tie to re-secure it. It was still clipped firmly in place yesterday - seemingly by the same cable tie!!!!!! Because of the way I had deliberately cut the tie right back, it was impossible to remove without cutting, and it could therefore not have been re-used.
So, looks like I was lucky on the drive home, and there may still be air in it - will now be re-bleeding it properly myself, before it goes on the road again, and I'll report here how much more coolant it then takes, if any.
