Oil leak from filter.
Dodders
Post by Dodders » Mon Aug 09, 2010 12:53 pm
Hello chaps
Go easy on a newbie! :D
My brother and I picked up a bongo at the weekend which had signs of a oil leak,The garage assured us this was fixed with a new filter and fresh oil.
Only last month the engine had a full rebuild which obviously had a new filter put on then, but that leaked as well(the garage said the first filter hadn't been tightened properly)
Is there a common problem with leaky filters etc? If so any fixes/tips/
Sorry for probably a daft Q but Bongo's are new territory for me coming from Mk4 golfs!
Cheers dodders
Re: Oil leak from filter.
Post by francophile1947 » Mon Aug 09, 2010 12:56 pm
It's not a general problem, but there was a batch of faulty futures that leaked. Should be OK now though :D
Post by missfixit70 » Mon Aug 09, 2010 12:57 pm
There were some dodgy filters knocking about a couple of years ago, but if it's happened with two filters, I'd check the sealing face hasn't been damaged. I take it the filter was put on with a smear of oil on the rubber gasket to stop it "rucking up" as it's tightened?
Welcome to the forum BTW :D
wormey
Post by wormey » Mon Aug 09, 2010 1:05 pm
Welcome, :D
I'm with you on the oil smeared on the seal Kirsty. Is it leaking now. if it is take it back.
Daz and debs
Dodders
Post by Dodders » Mon Aug 09, 2010 1:08 pm
Who knows, but its pithing oil out now when running.
Seems funny that two different garages can get it wrong.
Third time lucky maybe?
Just another thing,The bongo's in need of 4 tyres, which are all 215's reading on here I need to change the fronts to 195's,Yes?
Thanks for the welcome,think i might enjoy it on here :lol:
Post by missfixit70 » Mon Aug 09, 2010 1:09 pm
I'd definitely get the sealing face checked then, are you sure it is the filter it's coming from?
wormey
Post by wormey » Mon Aug 09, 2010 1:12 pm
I'd be looking at where its coming from and checking oil levels. They may have cross threaded the filter. If it is leaking I'd ring them and see about collection for repair.
Daz and debs
Post by francophile1947 » Mon Aug 09, 2010 1:15 pm
Dodders wrote:Just another thing,The bongo's in need of 4 tyres, which are all 215's reading on here I need to change the fronts to 195's,Yes?
No, especially if it's a 4WD. Loads of us use 215/65 all around. If you do get 195s, they will need to be 195/70 or you could wreck the viscous coupling on a 4WD. If it's 2WD, it doesn't matter either way 8)
Dodders
Post by Dodders » Mon Aug 09, 2010 1:18 pm
missfixit70 wrote:I'd definitely get the sealing face checked then, are you sure it is the filter it's coming from?
definitely a constant dripping when running.
Dodders
Post by Dodders » Mon Aug 09, 2010 1:20 pm
Sorry forgot to add that in the sig.
Yes its 4WD,so best to stick with 215's all round.
Post by missfixit70 » Mon Aug 09, 2010 4:36 pm
Let us know how you get on :D
Dodders
Post by Dodders » Mon Aug 09, 2010 6:29 pm
Cheers everyone for your help and advice. =D>
Just a thought I had, could it be that both garages put on the wrong size filter :?:
definitely the garage we bought from wasn't a specialist in Bongo's
Its booked in with Discount Trucks in Newbury on Friday, so,on the rep that they have on here they should (hopefully) sort it! :wink: hopefully they'll sort out the fuel gauge problem as well.
Post by missfixit70 » Mon Aug 09, 2010 6:59 pm
I had that thought too, if the first one put the wrong filter on & the second garage fitted the same as what was on there.... :roll: Discount Trucks'll sort it :wink:
wormey
Post by wormey » Tue Aug 10, 2010 7:28 am
I changed to 215's all round on my freda, it then juddered on the back end until I put the correct size tyres back on, mines a 4wd.
Daz and debs
Dodders
Post by Dodders » Tue Aug 10, 2010 11:23 am
Ooo! this is abit confusing :?
Do you all recomend sticking with 215's all round or putting 215's on front and 195/70's on back :?
