Removed roof bars - now have holes in roof!
hembramacho
Post by hembramacho » Mon Aug 09, 2010 8:11 pm
As it says, I removed my roof bars today in order to be able to fit my new AFT rain cover and now I have 4 holes where the bolts fitted. I'm wondering what the holes originally had filling them, as they surely can't have come new like that. I don't really want to leave them with the holes open (currently have bolts sticking out of them!), so can anyone shed any light on this or suggest anything to plug them with?
Andrew
Re: Removed roof bars - now have holes in roof!
Post by missfixit70 » Mon Aug 09, 2010 8:16 pm
Did the blind inserts come out then? Or weren't they there in the first place?
hembramacho
Post by hembramacho » Mon Aug 09, 2010 8:47 pm
missfixit70 wrote:Did the blind inserts come out then? Or weren't they there in the first place?
Blind inserts?
The roof bars were already on my bongo when I had it, so I'm presuming what was originally in the holes before the roof bars were fitted were removed and 'put in a safe place'.
Next question - where can I get some from? Breaking bongo's?
Andrew
Post by missfixit70 » Mon Aug 09, 2010 8:51 pm
Worth a try, not sure if either of the guys in the breaking bongo's section had afts? wouldn't think they'd be a high demand item so should be plenty of spares around form the usual suspects like bongobits, bellhill, wheelquick, Allans, etc if no-one on here comes up with them, or this one may help for now - http://www.igmaynard.co.uk/bongo/forum/ ... es#p433277.
hembramacho
Post by hembramacho » Mon Aug 09, 2010 9:10 pm
Thanks Kirsty. I'll ring round in the morning, unless someone can come up trumps on here. Thanks for the link to the other thread too.
Andrew
wormey
Post by wormey » Tue Aug 10, 2010 12:11 am
You could just put some bolts the right length in the holes, I look at the size in the light. :D
Daz and debs
Post by francophile1947 » Tue Aug 10, 2010 9:52 am
Neither of mine have bolts in them - just the threaded holes.
Triple/R
Post by Triple/R » Tue Aug 10, 2010 10:05 am
francophile1947 wrote:Neither of mine have bolts in them - just the threaded holes.
Same as mine~just threaded holes~so can't see the problem 8)
Regards Ray & Christine
hembramacho
Post by hembramacho » Tue Aug 10, 2010 10:37 am
I'm obviously looking for something that doesn't exist then. #-o
I wrongfully presumed that the bongo wouldn't have come new with 4 holes already in the roof and would have an original plug or something. I'll get me coat! :oops:
However, one of my threaded 'holes' actually was loose as it dropped down through the hole :shock: . Only when I raised the AFT did it drop down below, and was one heck of a job to get back in from underneath the AFT as the rail goes straight over it, but there is the slightest of gaps you can squeeze it back in and screw in a bolt from above - if nothing was screwed into it from above it would just drop back down, hence my thinking that there must have been something there originally!
I would prefer to plug the hole on the top as any water could seep through if it or any of the others drop out. Although the water would not get directly inside the fabric, any water trapped there would not be a good thing I'm presuming!
Andrew
Triple/R
Post by Triple/R » Tue Aug 10, 2010 10:54 am
Eyup Andrew :) ~you could fill holes with silicone then if wanting to fit roof bars again it's easy to dig out & reveal holes.
hembramacho
Post by hembramacho » Tue Aug 10, 2010 11:08 am
Triple/R wrote:Eyup Andrew :) ~you could fill holes with silicone then if wanting to fit roof bars again it's easy to dig out & reveal holes.
Thanks - possible idea. I'm now wondering though whether I'm creating an issue that doesn't exist, as no one else seems concerned there are 4 holes in their roof!
Andrew
wishmaster
Post by wishmaster » Tue Aug 10, 2010 11:10 am
What about some rubber grommets :idea: any good diy store should stock them, measure the hole for a good tight fit :)
Izzy
I have a plan and its as HOT as my pants
IZZY
http://s633.photobucket.com/albums/uu57/izzy2619/
munroman
Post by munroman » Tue Aug 10, 2010 11:39 am
Hi, the roof 'holes' are used in the factory to lift the roof on, so all factory AFT's will have them.
8mm bolts will screw into them, but the holes don't go through the roof, try putting a match down the hole and you will feel that it stops partway down, so you won't get lots of water running through.
If you are ever thinking of putting roof bars back on, let me know, as I think I might have a solution which would allow you to have roof bars when required, without getting in the way of the AFT cover.
When asked about Western Civilisation, Ghandi said 'that would be a good idea'...
the guvnor
Post by the guvnor » Tue Aug 10, 2010 11:44 am
ive got holes aswell :wink: ..........but i want some roof bars to fill them ! [-o<
dandywarhol
Post by dandywarhol » Tue Aug 10, 2010 1:38 pm
The "female" roof inserts are screwed into a "nut" which fits from the inside - this can work loose - tighten the "nut" from underneath the roof and the inserts won't come out or leak water
